Question about Hayward Pool Products HAYWARD 1.5 HP 2 SPEED SUPER PUMP - INGROUND POOL PUMP -
Replacement parts not matching # in Hayward Power-Flo manual
Does strainer cover SPX1500-D-2a replace SPX1500-D-2 as listed in manual? Cannot find one without the "a"
  • 990 Answers
I would think so. It is probally a newer model with heaver ribs or stronger plastic. They find weakness in these and fix the newer ones. So I would guess so.
Posted on Apr 24, 2010
Closed and opened shut off valve to strainer housing basket, no water in strainer, how do you know if shut off knob actually opened or just broke the knob?
if the basket fills with water once you open the strainer lid then the valve is opening properly. If you open the valve and the strainer lid but you see no water flowing in then you can believe that the valve is not opening and needs to be fixed or replaced.
May 20, 2015 | Hayward Pool Products Hayward Power Flo LX...
How do I get water in the strainer housing basket?
guess you need to add some water they do not self fill usually .
Seal leaks on my power flo lx hayward pool pump
The seal can be replaced with either a 2131 or 200 seal from any pool store in your area. Most can offer tips on how to replace the part if you need guidance. The seal should be under $20 and could be as little as about $5.
Aug 21, 2010 | Hayward Pool Products Hayward Power Flo LX...
This June, I had to replace my strainer housing on my Hayward Power-Flo Matrix pump. It cracked in cold weather before I remembered to remove it. On installing a replacement, I noticed that the pump showed...
One or more of a couple issues is at play here. First would be the seal replacement. Even if you used the correct seal if you touched the surfaces or failed to install it properly it can and will leak. Second, inspect the housing around the seal fit and the stem of the impeller for cracks. A hairline crack is enough when placed under pump operating pressure to allow a leak. Somewhere in there is your solution.
John
Jul 17, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
The pump strainer has a crack near the drain plug? I can't find a replacement without replacing the whole pump. I have looked online for a part # and can't find one.
After market parts are hard to locate for these pool filters. You might want to check will local pool equipment repair companies that may have spare parts. Hayward might be able to provide you with a list of dealers that carry after market parts.
Jul 05, 2010 | Hayward EC-40 DE Pool Filter with pump
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Jul 19, 2009 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Hayward Pool Products HAYWARD 1.5 HP 2 SPEED SUPER PUMP - INGROUND POOL PUMP - Logo
90 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
