Question about Fisher and Paykel GWL11 Top Load Washer
Our Fisher & Paykel GWL 11 will not stop adding cold water at the point where it finishes the initial wash cycle (first light) and begins the agitation cycle (second light where the tub fills and it agitates for three lights). If I can catch it at this point and turn the cold water valve off it stops filling and I can open the cold water valve again and it continues as normal. If I don't catch it, then it keeps filling and emptying (siphon effect?) while beeping and flashing the last wash light and first rinse light. Is it the cold water valve, the level (pressure?) sensor, or the control board?
  • aemibarry Apr 28, 2010
    I'm thinking the same thing, however the washer does let shorter sprays of cold water in during the spin cycle like it is designed to. Today I have been using it and turning off the cold water where I have to in the cycle to keep it from going into the "Flood" warning. Now it is filling very slowly. Does that sound like the cold water valve is experiencing further failure? Thanks.
  • 4,070 Answers
Water inlet valve. It's at the back where the hoses connect to the washer. You may have to remove the back to access it.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Posted on Apr 24, 2010
  • Charles T Nevin
    Charles T Nevin Apr 28, 2010
    If the valve is sticking because of sediment getting in it , it will work at times and when you cut the water off is may be letting the grain of sand etc. dislodge. When it just trickles in the sediment or wear isn't letting it open all the way. If you can swap the two wires on the cold with the two wires on the hot valve or swap the hoses so that the hot water valve is working you can see what it is. It should work normal except you'll be getting hot water.
Washing machine won't drain or finish cycle
It sounds like you have a drain pump stopped up or failed. Do you hear any noise when it is supposed to be draining? A humm or buzz?
Oct 31, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Washing Machine Model GWL 11
The power supply needs three resistors removed,R129,R130,R131.
and one 1megOhm put in it's place.
Feb 25, 2012 | Fisher and Paykel Washing Machines
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
My gwl 15 ecosmart
having the same problem myself i am replacing the soliniod when it get here. in the mean time the hot water runs in normally so i swapped the hoses over on the back and and now i can wash just that the hot is now the cold button
Dec 04, 2007 | Fisher Paykel EcoSmart GWL15
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
102 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
