Question about Canon PIXMA MP150 All-In-One InkJet Printer
My printer says the number2 the e what should i do i have replaced the ink
    Scholar:
  • 67 Answers
E, 2 is an alert that the paper is not as being correctly loaded into the paper tray. Remove your paper and get a fresh, dry supply of new paper. I suggest using only five pages or so, and separate them to remove static. Place them into the feed tray and get the guides so that the paper is properly aligned...not too tight and not too loose. Try printing. If you continue to get the error code, remove the paper and make sure there are no obstructions anywhere in the paper path. Sometimes when users get a jam, they snatch or roughly remove the page and tear tiny pieces off that remain inside and can block sensors. If you find any bits of paper, remove and cycle the power and then try to print again.
Posted on Apr 24, 2010
Ink light is on. which cartridge needs to be replaced
The printer's indicator lights tell you when to obtain a replacement ink cartridge by flashing when ink is low, and when to replace an empty ink cartridge by remaining on when ink is depleted. The LCD panel also displays INK LOW or INK OUT.
Even if only one ink cartridge is empty, the printer cannot continue to print.
Nov 24, 2014 | HP DeskJet 960c InkJet Printer
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Erorr 402
transfer unit spring missing spring number2 good luck
Jun 10, 2011 | Ricoh Aficio 450 Copier
Need to change ink catrege help
Using the printer's control panel In some circumstances, you may need to replace an ink cartridge before it is empty.
If the fonth.gif ink out light is flashing or is on, replace the empty ink cartridge as described in Replacing an Empty Ink Cartridge.
To replace an ink cartridge before the fonth.gif ink out light flashes or the Status Monitor notifies you that the cartridge is empty, follow the instructions in this section.
r_caut.gif Caution: r_space.gif Do not remove the cartridge from the printer until you are ready to replace it with the other one.
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
r_2.gif Lower the output tray, then open the printer cover.
r_3.gif Press the fonth.gif ink button. The print head will move to the ink cartridge replacement position, and the fontp.gif power light will begin to flash.
r_space.gif r_note.gif Note: r_space.gif r_space.gif Do not press the fonth.gif ink button over three seconds. Otherwise the printer starts cleaning the print head.
Jun 13, 2010 | Epson Stylus CX6600 All-In-One InkJet...
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
HOW TO PROGRAM ARITHMETIC ALGORITHM( ADDITION)IN C++
above int main () you will want "using namespace std;" without quotes. Under that, "int main ()" without quotes, then a [ bracket to start the main function.
Please rate, thanks!
Mar 16, 2009 | Computers & Internet
I want to align printf()'s text in center.
printf("Color %s, number1 %d, number2 %05d, hex %x, float %5.2f, unsigned value %u.\n",
"red", 123456, 89, 255, 3.14, 250);
will print the following line (including new-line character, \n):
Color red, number1 123456, number2 00089, hex ff, float 3.14, unsigned value 250.
The printf function returns the number of characters printed, or a negative value if an output error occurs.
for further inf u can see.
http://en.wikipedia.org/wiki/Printf
Nov 26, 2008 | Computers & Internet
Ricoh Aficio 450
Press the diamond button to the left of the display then press number press next until you see number 6 marked configuration then press number2 tcp/ip input your ip and subnet press the #button to set the data cheers dr bob1
Mar 22, 2007 | Ricoh Aficio 450 Copier
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
