Question about Acer 22" X223w LCD Monitor
Monitor not working it lights up and says acer then it says no signal and goes blank
    Scholar:
  • 49 Answers
There are two common reasons for that problem. 1) Your video card on your pc may be having issues. 2) Your monitor is not working properly
Here is a test to isolate the problem to the monitor. Plug it into another pc or laptop VGA or DVI slot and try to power it on again. If it works then you know for sure it's your video card giving trouble. Either gone bad or needs the drivers to be updated/uninstalled and reinstalled.
If it doesn't work then you're looking at some monitor repair or potentially a new one. However since you said you saw the Acer logo, it's a positive sign it's not really your monitor as it would not work all together if it had an issue.
Hope this helps and thanks for using FixYa.com
Posted on Apr 24, 2010
Bogdan
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
tantong
  • 138 Answers
SOURCE: Blank ACer X221W Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went dim and blank, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Mar 06, 2008
SOURCE: Monitor comes up shows "acer" then says no signal and goes black
Acer Field Service Bulletin
DATE: 04/03/08 NUMBER: mn_029
SUBJECT:
REVISED - The message "No Signal" sporadically appears on the screen.
AFFECTS: X241 monitors ET.L990B.029
ISSUE:
This is an update to the document original published 9/19/07
While the X241W monitor is in use, it might show "No Signal" on screen abnormally.
Sometimes, the monitor may still continue to display video.
Other times the monitor may be go black. For some customers, the problem will correct itself in a minute. These problems often occur during the first 20 minutes the monitor is powered on.
SOLUTION:
Short term #1 – Unplug the monitor to reset the video controller.
Long term #1 - The main board firmware can be reflashed to a newer version of
firmware by an Acer authorized monitor repair depot. The latest firmwares are listed below.
for monitor with s/n version “00” and ”10” FW = WDTD-D1AP0 V1.03
for monitor with s/n version “12” FW = WDTD-D1SP0 V1.02
for monitor with s/n version “13” FW = WDTD-D2AP0 V1.03
ACTION REQUIRED:
Confirm the firmware has been updated prior to returning the monitor to the customer
or to stock.
When an Acer service repair technician updates the firmware, they should record that
the part IN-MONITOR was used.
SPECIAL TOOLS
6K.ISPVE.001 Tool Kit with a corresponding DB-15 and Serial data cable.
USB-A to USB-B cable for power.
PARTS REQUIRED
Replace main board if firmware update does not resolve the problem. See spares parts list for p/n.
Posted on Jun 07, 2008
  • 1632 Answers
SOURCE: Monitor goes blank (black) after some seconds, power light stays on
Change to new monitor
Vitally
Posted on Jun 02, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
Hi there. My monitor has been working fine up to yesterday. I have all connections plugged in and i turn on the monitor and then the ACER sign comes up and then it says No Signal. and then the blue light...
Your monitor is fine, the problem lies with your computer. Your monitor is not receiving the POST signal from your computer. I suggest you remove your computers graphics card and plug your monitor cable into onboard graphics, then power up and see if the monitor gets a signal. If it does then it means that your graphics card has stopped working. If you still don't get signal then I suggest you take your PC to your local computer shop and get a qualified technition to have a look at it just in case the motherboard is damaged. You can also try out your monitor on another system just to be sure.
Feb 12, 2011 | Acer X233H 23" Monitor
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
Acer monitor says no signal, then goes blank. Is
We are using the same monitor type.. humm it's good that i already had experience with it. No drivers needed to install this monitor, check the connection to the PC and to the monitor, make sure they are inserted properly. Sometimes when you put on the PC first and then power on the Monitor causes this problem. The best recommend resolution is 1440X990, good luck..
May 15, 2010 | Acer AL1916W 19" LCD Monitor
No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Mar 06, 2010 | Acer 22" X223w LCD Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Upon booting, fans whirl and I can hear HDD
Sounds like your graphic card is not working. Try replacing that. Check and make sure you have the cable plugged into the right port in your graphics card.
Aug 27, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Screen Goes Blank
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
Acer 22" X223w LCD Monitor Logo
149 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
