Question about Whirlpool Dishwashers
A built in whirlpool dishwasher is leaking around the door seal, right side to be more specific. cleaned the seal, and along the bottom and it still leaks. Is there an adjustment that can be made to tighten the door. I wouldnt think it would be the seal itself do to being less than 2 years old. Thankyou for this service.
    President:
  • 949 Answers
There is no adjustment per say on this door or seal. If water spray directly on the door it can cause this, what I mean by that is if the spray arm, either the upper or lower is stuck and continually sprays in one place it can cause the water to leak by the door.
If the wrong type of detergent got in the dishwasher and there are suds or foam this could cause the dishwasher to leak a bit too.
If the dishwasher is not level or not mounted tight the door may not be hitting the seal right.
If all of these are not the problem I have heard of people putting a bit of silicone behind the gasket in the area it leaks, this will make the gasket a bit thicker to possibly help.
Posted on Apr 25, 2010
We have water leaking out of the left side of the dishwasher occasionally. About 1 in 3 loads will leak. Most of the time it is a small leak 1/4 cup or less but once it was a spray out.
One (or possibly both) of your door seals needsreplacing. It's more likely to be the lower door seal as these usually go first. This seal isn't visible like the goalpost seal that runs around the sides and top of the wash compartment. If you open the door, you can feel this rubber seal when you run your fingers along the bottom of the door on the inside. Be careful though, as there is often a build up of dirt down there!
I don't advise buying any parts until you are certain of where the leak is coming from. Identifying the source of the leak (and therefore which seal to replace) is relatively easy but the best way is to run a wash cycle with the front panel of the door removed. It's quite easy to remove, but you might need a T20 T-Star screwdriver to remove it. Sorry, I can't remember exactly what the fixings are on this model.
A simpler - but not always accurate method - is to check by look and feel. If the water seems to be coming from the sides of the door panel at the bottom when you run a wash cycle, it's the "goalpost" seal that needs replacing. These are easy to obtain and replace - they simply push into a slot.
To test the bottom door seal, run any wash cycle and, when it's finished, stand to the side of the washer and open the door. There is a white plastic panel under the door. Have a feel around on top of this. If it's wet you probably need a new lower door seal. These are much harder to replace as it involves removing the door panel and partially releasing the hinges. I don't recommend this as a DIY fix unless you are competent, confident and have good instructions - i.e a service manual!
Whichever seal you need, they cost around $30 / £20 each.
Please rate this solution if you find it helpful. Thanks.
Oct 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Neff built-in dishwasher and sometimes there is a heavy leakage of water from the front right-hand side. The unit is 3-years old and there is a build up of scale around the rubber seals. The long...
Check the rubber seal in the bottom of the door has not perished or split,also check the bottom spray arm has not split on the ends as this will direct the spray directly onto the door,causing it to leak.
Hope this helps
Sep 19, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Eurotech Dishwasher is leaking - How to get to the guts to fix it
When a dishwasher leaks, it is usually the door seal or the water level gone wrong. Assuming the door was never leaned-on and the hinges bent, then you look to the seal or in some cases a splashshield fin that goes along the bottom between door and frame. If the unit is more than 7 or 8 years, the seal or shield plate could have lost its shape enough to allow water to get by.
The other problem, is the water level is too hi and this can be because the float switch is filled with soap scum and is heavier than normal, so the float thinks there needs to be more water than usual. Clean the float, you may need to remove a guard shroud to access the float. Goodluck, macgivor
Jan 02, 2010 | EuroTech EDW242C Stainless Steel Built-in...
My dish washer is built in and it is leaking at either side of the door at the bottom
The symptoms you describe, sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps.
The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub.
Some other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of about $70.
2. Replace the door seal at a cost of about $7.
If you need parts, the cheapest place I could find them was pcappliancerepair.com.
If the model number you have this question listed under is correct, the part numbers are as follows: Inner Door Panel - 154494601 Door Seal - 154561001 NOTE: The inner door panel is listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges.
If you have questions, or require additional assistance, please post back with a complete model number so that I may be able to provide you with better service. hope this helps you.
Oct 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
I have a leak when the dishwasher is running.
This is commonly caused by a worn door seal. This is a simple repair that requires no tools and can easily be accomplished in a matter of minutes. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. The only other items that can contribute to leaking are:
1. Replace the inner door panel (part number 99003678) at a cost of about $115.
2. Replace the door seal (part number 902894) at a cost of about $40.
I think I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps: 1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way. 2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results. 3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers. 4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side. 5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary. This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 08, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
My whirlpool dishwasher is leaking water from the bottom of door
Water is being forced out under the bottom door seal. Is the lower spray arm melted on the bottom? Or is there something directing the water flow toward the bottom of the tub instead of up toward the dishes?
Sep 03, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool dishwasher leaks
Just about all dishwashers will leak a little around the door seal over time but should not leak to the point of wetting the floor. With the door open, check in the front of the tub, under the door. Lots of gunk? Clean this area out well plus take a soft damp rag and clean the door gasket while feeling for any damage. Then go along the mating surface of the door and look for any nicks. If it leaked all the time I would suspect the door hinges have been sprung. Hope this helps, Ken
Apr 26, 2009 | Dishwashers
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
189 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
