Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
My vectra remote electric fire stopped workin after 15 months. This is the second time this has happened. The first time was within 12 months and so the fire was replaced.Can you help?
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
2000 Reg Vectra Engine Management Light On
Have you cleared all the faults?
Try it again after clearing.
Feb 18, 2014 | Cars & Trucks
My key remote to lock the doors suddenly stopped
hi yes this can be done, here is how
make sure you have all keys ready to reprogram close all windows and doors insert key into drivers door lock within 5 seconds of putting key in door lock turn key to unlock position 3 times this puts the key into programming mode ( door led should be on ) press and hold lock button, within 5 seconds of holding lock button press unlock button 3 times ( keeping lock button pressed at same time) then release lock button that should be it...to make sure correct programming is achieved key led flashes 5 times, and door led flashes 6 time, if you have more than one key do same as above within 15 seconds of doing the first key..
phew..lol, well i hope that will work for you..please vote thanks
May 14, 2010 | 2007 Ford GT
Copier/Printer Pproblem
what it means......
541 A Fusing thermistor open
The fusing temperature did not increase
12 °C at the center or ends of the hot
roller within 2 seconds after two checks
from the time the fusing lamps turned
on.
what could cause it.....
Fusing thermistor out of its position
because of incorrect installation
• Fusing thermistor disconnected or
defective
• Power supply not within rated range
(15% or more below rating
What to do if your not a technichian you should have one check it out
there are some high tempetues invoved ..the code is there to prevent fire hazzard
Jan 31, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
15'' electric string trimmer start/stops
IF it humms but not turning then it may be jamed.
If it dose nothing it may have a lose connection on the inside of the housing /cable jamed on seal joints when made over time this will break and so leaving you with an non working plastic shell.
Aug 16, 2009 | Garden
Lost my manual and cannot remember how to get messages remotely
Since I have not idea what exact model you have this may or may not work... I hope it helps, as it is for a Uniden answering service phone.
Remotely Operating Your Answering Machine
Note: The answering machine will only playback messages for four minutes and then it returns to the command waiting mode.
To continue playing your messages, press [#] then [2] again within 15 seconds.
To operate from a remote location, use any touch-tone telephone and follow these steps:
1.) Call your telephone number and wait for the answering machine to answer
2.) During the greeting message, press [#] and enter your PIN code within 2 seconds;
How to enter a PIN
To play your messages from a remote location, you will need to enter a two-digit Personal Identification Number (PIN) or PIN Code.
Press the MENU soft key. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
Enter a two-digit security code (00-99) using the number keypad [0-9].
Press the OK soft. You will hear a confirmation tone.
The answering machine announces the current time and the number of messages stored in memory.
You hear "To play incoming messages, press pound-two. For help, press pound-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following:
# then 1 Repeat a Message
# then 2 Playback Messages
# then 3 Skipping a Message
# then 4 Deleting a Message
# then 5 Stop Operation
* # then 6 Answering Machine On
# then 7 Memo Record/Stop**
# then 8 Greeting Record/Stop**
# then 9 Answer Machine Off
# then 0 Help Guidance
Apr 27, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Hampton Bay remote for ceiling fan caused an electrical fire
We just installed this fan and within 1 day the electrical wires in the receiver burned and would have caught fire had it not been caught!!!
Jan 07, 2009 | Universal Remote Control Hampton Bay...
Timer in auto start.
if it is the 2000 rs the manual can be downloaded from scytek.net
1. Turn on ignition.
2. Within 5 seconds, press the valet switch 5 times.
· The parking lights will provide three blinks, indicating that you have entered Programming.
3. Press the valet switch 12 times (engine run time)
· The parking lights will flash each time the valet switch is pressed.
4. Within 5 seconds, press the transmitter button corresponding to the desired time ( left button 15 min, right button 25 min)
· The parking lights will flash to indicate the setting.
1 flash = 15 min
2 flashes = 25 min
5. When you are finished, turn off the ignition to save the changes.
all of this is based on that it is the galaxy 2000rs m,
Nov 19, 2008 | Scytek 2000RS-M Remote Control
Heating & Cooling Logo
61 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
