Question about Kodak EasyShare C340 Digital Camera
Wil not transfer
In the past I was able to transfer pictures onto my computer.I changed the memory card and now the pictures wont tranfer.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 26, 2012
  • 684 Answers
SOURCE: Kodak 2gb memory card picture shows on camera but not computer
The Memory card is defective if u continue to use the same memory card more pictures which u take may spoil so pls try to use a diffrent memory card it will work fine.........
Posted on Dec 15, 2008
robmcd27
  • 423 Answers
SOURCE: Need to put Pictures from Camera onto Memory Card
Hi there. Here is how you do it. Go into the menu and navigate to the Copy screen. Choose an option. One is to copy pictures from the camera's internal memory to the SD card, and the other is copy from the SD card to the camera's internal memory. Then press OK. On the next screen, you have two option choices, either copy all images, or selected images. Hope that helps.
Posted on Feb 17, 2009
  • 102366 Answers
SOURCE: how to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
Posted on Mar 31, 2010
  • 19 Answers
SOURCE: copying pictures from computer to memory card
i have seen this error and i dont know why it does that. you may want to try buying a micro disk setup that fits into a sd adapter that will fit in your camera.
then you can take out the micro disk when full and put it on a usb adapter and plug right into a usb port.
i know this sounds like more work but so far i havent had a lock up on that or error yet. go to tigerdirect.com if you want to see the different adapters for the sd disk and micro disk and usb etc....
maybe this might help
Posted on Apr 27, 2010
  • 102366 Answers
SOURCE: transfer pictures from camera to card
First, make sure there's a card installed and that the camera's image storage location is set to internal memory.
Press the Review button, then the Menu button. Use up/down to highlight Copy, then press OK. Use up/down to highlight an option, then press OK.
You set the image storage location in the Setup menu.
Posted on Jun 01, 2010
My d5000 wont tranfer pics to camera. bought new computer cord for camera and still wont work
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
Apr 30, 2012 | Cameras
Cant put pics onto my memory card for my camera help?
You can't transfer pictures from internal memory to a memory card, sorry. You need a USB cable to connect the camera to your computer then you can transfer the pictures to the computer.
Hope this helps.
Thomas
Jul 21, 2011 | Fuji Cameras
How do you put your pictures saved onto your camera onto your memory card?
If you saved the pictures to your cameras built in memory, chances are that you cant transfer the pictures from the camera straight to the memory card. You have to FIRST transfer them to your computer and THAN from your computer to your memory card.
Mar 08, 2011 | Cameras
I have a Fuji FinePix F480 which is brilliant but it isn't downloading all my shots onto my computer. It is showing a message that I have internal pictures. My question is how do I get these pictures to...
I've attempted in the past to download from the internal memory to the computer before with no success. What you can do is put the memory card back into the camera and transfer the internal pictures to your memory card (your camera refers to these as "frames"). I'm not sure if you have a manual or not but what needs to be done is selecting copy using the multi-control button on the back of the camera select "IN" for internal and arrow from internal to card. the only sticky thing about this is you need to do one "frame" at a time. Make sure you have the room on your memory card before doing this. You might want to format the memory card first before you do the transfer from internal memory to your memory card. Then once the Internal "frames" are all on the memory card you can down load them to the computer as "normal"
Dec 18, 2010 | Fuji FinePix F480 Digital Camera
My camera says the pictures upload onto my computer but then nothing happens after that....the pictures dont upload what is the problem?
Internal Memory: 32MB
SD Card / SDHC Card (Up to 4GB support)
Possible that internal memory is empty and your are transfered zero file. Switch to external SD memory in your camera menu should take care of the problem. Get the SD card reader is your easiest option. just copy and paste the photos to my picture in your computer.
Apr 05, 2010 | General Electric A835 Digital Camera
I have a disney micro digital camera, where i can get a free download to transfer the photos from the camera into my pc?
Your camera has a SD card slot. If you have one of these in your camera then it is just a matter of transferring them from the card to your computer. Most stores that carry the SD cards will have a card reader you can buy. You connect the card reader to your computer and insert your SD card into it. From there you can open up this card reader in MY computer, select your photos, right click and hit copy. The you open up the file you want to put them in (like my documents then my pictures) and right click again and go to paste. This wil transfer all those pictures you have selected onto your computer but they will still be on the SD card too. Hope this helps. The card readers cost about $20 give or take.
Jul 19, 2009 | Disney Pix Micro Digital Camera
Transfering photos from my compuer photo gallery to my camera
Make sure photo files name must be under DSC00001 to DSC99999
connect your camera to computer, click My Computer, Removable Disk, Folder and copy photo files from computer and paste in that folder. If file name is different, camera will not show it in playback though file is in memory stick.
May 18, 2009 | Sony Cybershot DSC-T200 Digital Camera
Downloading photos from computer to phillips 8ff2fpb photoframe
Your PhotoFrame does not have internal memory acording to the Phillips data sheet, therefore you need to load your pictures directly onto a memory card (one from your camera will proabably work.) If that isn't convenient, you can generally get a good price on a SD memory card which is supported by your PhotoFrame.
If you wnat to transfer pictures from your PC to the memory card and have a card reader, you can transfer the pictures in Windows Explorier from your PC to the memory card and then plug the card into your PhotoFrame. If you do not have a card reader, plug the memory card into the PhotoFrame and connect it to your PC using a USB cable (you may have to buy one as acording to the Phillips data sheet it is not supplied.) When the PhotoFrame is pluged in it will appear in Windows Explorier as a new hard drive, and you can copy your pictures to it.
I hope this helps,
Mike
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
How do I transfer pictures onto the memory card?
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
Oct 05, 2008 | Nikon Coolpix 2000 Digital Camera
Memory Card
If you transfer the photos to your computer from the camera, you should be able to save to another memory card. I can't say whether or not the photos on the new memory card will show up on your camera since there may be certain requirements to display on camera screen.
Plug your camera into the computer USB or insert old memory card. A box should pop up giving you the option to view files. Copy and Paste (or Drag) selected photos to a specified folder on your computer (Like My Pictures in My Documents). Insert new memory card. Copy and Paste (or Drag) selected photos to the drive for your memory card.
May 06, 2008 | Samsung Digimax S630 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
44 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
