Question about Garden
I would like to know the best way to change the blades on a42in lawn tractor it has 2 blades thanks
  • 2,841 Answers
The very best and easiest way to remove the blades is with an air impact wrench. With an impact wrench it is simple as you do not even have to hold the blade, but with a ratchet and socket you must hold the blade while trying to remove the bolt. Use a piece of wood to wedge the blade so it cannot move.
Posted on Apr 24, 2010
Testimonial: "iappreciate the imformation about changing the blades on my lawn tractor. i don't have a impact wrench i have only a rachet and socket. thanks alot"
What is the best linement of the blades for maxiunm lift for mower vacumm
There is no linement for the blades as the blades you buy now days has a great amount of lift just be sure you keep your blades sharp and watch your grass if the mowed grass has jagged edges then the blades are getting dull. But your blades won't stay in line anyway, as the grass will change them. Good luck, and let me know if you need anything else....
Aug 21, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Belt diagram for a murray 46 model 46573X92A
This has a couple of diagrams with belts. Hopefully it has what you need. If not let me know and I'll keep looking for you.
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-46573X92A-LAWN-TRACTOR-(1998)-PARTS-LIST.pdf
Jul 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
What is the easiest way to change the blades on my yth23v48 rider
Blade removal instructions on page 15 of your manual state the best, conventional way (without removing the entire deck).
http://www.husqvarna.com/ddoc/HUSO/HUSO2011_NAen/HUSO2011_NAen_YTH23V48_532438710.pdf
Sep 13, 2011 | Husqvarna YTH23V48 23HP Lawn Tractor 960...
Change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Nov 02, 2010 | Troy Garden
Mowing the lawn high and low
Mowing the lawn low and hi can only mean where are the adjusters or which is best.
The best height for grass is about 2 - inches for my nickle. There is no best - it is to your taste.
As for adjustments on your unit they are done with the handle that sets your deck height.
Let me know if after reading the instructions you still need help.
thanks
Gary @ Fix Ya
Jun 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine slows down with blades are engaged?
sounds like the blade spindles are binding, many have Zerk fittings to grease them. with belt disengaged try turning the pulleys they should turn easily and have no wobble in them. if either is wrong replace spindle and best to change in sets. this is the most common issue.
Apr 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a murray riding mower with twin blades..how to change
take a socket rench with 2 feet pipe....slide the rench handle to the pipe and that well give you enough power to turn you have to hold the blade with something from turning .....ometime you can hold it with a towel
Oct 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Aug 22, 2009 | Garden
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
