Question about Frigidaire ATF6000ES Front Load Washer
Washer is showing error message E20 - Frigidaire ATF6000ES Front Load Washer
    Sergeant:
  • 239 Answers
No drain error
Posted on Apr 25, 2010
How can I fix E20 error on washer
COULD BE EITHER? U HAVE TO CHECK THE HOUSE DRAIN AND THE HOSES AND WATER PUMP FOR OBSTRUCTIONS
Feb 16, 2014 | Frigidaire ATF6000ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Error message E20
Hi... error E20 means your washer can't drain you may need a new pump or something is in the pump
Apr 07, 2011 | Frigidaire ATF6000ES Front Load Washer
Zanussi washer dryer showing e20 error message in dryig cycle
Hi
This means that the filter is clogged. Unscrew the filter it'll be full of lint. E20 also means drain problem. If it actually goes through the Spin cycle then there is most likely some water still not drained out at the time of the tumble dry. Check the drain and the hose to make sure it isn't clogged.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 03, 2011 | Zanussi Washing Machines
E20 message want spin
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigidaire front laod washer has an E20 error message.
E20 error is known for pump out issue.The first thing I recommend is to take off the front bottom cover(below the door) tilt the washer back some,remove the clamps and hoses from the drain pump.It should be on your right hand side.Check the pump and hose to remove the clogging.This tends to be a common problem with Frigidaire front loaders.Now when you all done with that put it back together and do a test run.
Apr 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Frigidaire ATF6000ES Front Load Washer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
