Question about Zebra 110Xi III Plus Thermal Printer
I am not able to pring out labels , it sayse "error condition ribbon out and then Printer Idle V60.13.0.13Z The power light is green and solid the error light is blinking the check ribbon light is on solid and the pause light is on solid
    Scholar:
  • 97 Answers
The printer thinks it is out of ribbon. If the condition exists and there is still ribbon in the printer, then try pressing the CALIBRATE key to have the printer readjust for the label / ribbon. If that does not help then press the SETUP key, press PREVIOUS until you see a setting called RIBBON LED. Make sure there is a value there - should be somewhere around 30-40. If it is above 100, then lower the setting to 30. Then press SETUP again and press SAVE for a permanent save.
Hope that helps !
Posted on Apr 24, 2010
Error condition power supply
Dear,
you have not mentioned, whether print continues with that error or it doesn printer..?
anyway,
first thing, check your power cable.
If that error is on, it means that label media or ribbon sort of errors.
try re inserting both ribbons and media.
if tat error is flashing and printer continues printing, it may coz of over heat of head..! if so try reducing the pressure of the head.
if you are using continous labels, then calibrate the media and ribbon sensor.
for more details, please reach us.
www.trridevlabelss.com
Feb 05, 2013 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
When I try printing, the label sheet comes out without being printed then stops and the "condition/error" lights blink.
First you need to check the blink rate:
If fast this denotes a ribbon error - check ribbon is installed correctly.
If slow this denotes a label sense error - check the sensors are clean and are correctly aligned.
Aug 29, 2011 | Citizen CLP-621 Label Printer
I have a Zebra 105 SL, I have the ribbon installed but the printer tells me that the ribbon is out. I've tried changing the ribbon and labels out but as soon as I power it back up and try printing again...
Calibrate the printer from the setup menu.
You'll (1) Load the label backing with the ribbon (2) remove the ribbon - just shove it to the right, out of the way of the ribbon sensor (3) reload the label and ribbon.
The printer will run a number of labels out.
Feb 16, 2011 | Zebra 105SL Thermal Label Printer
Power light lit Pause light lit data light flashing and display saying printer idle , ribbon out
Press the pause button to take the printer off pause...
The data light is flashing because it has labels to print...
Check to be sure your ribbon is loaded properly.
Jun 20, 2010 | Zebra 203DPI Printer
Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
Aug 10, 2009 | Zebra 105SL Thermal Label Printer
Hi, my printer is printing blanks. Windows XP, Zebra ribbon I replaced the ribbon and still no luck. I tried setting the darkness to maximum, but that didn't work either. I tried the "dump"...
The zebra ribbon has ink on one side and the other side has a backcoating which protects the printhead. simple way to check is to peel off a label and momentarily stick to ribbon and remove. This will show you which side is inked.
If ribbon is installed correctly then reset the printer and re-calibrate it. 1. install labels and ribbon 2. power on printer. If you have a solid green light on then 3 turn printer off. 4 hold down feed key 5 power printer on and after 2 seconds release feed key. printer will perform a calibration routine and eventually print out status page. IMPORTANT 6 Hit Feed Key once more. Printer will display Out Of Dump message. Your printer has now been sucessfully calibrated.
May 06, 2009 | Zebra LP 2844 Thermal Printer
One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
These 2 links will help you troubleshoot the problem:
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Light is red and not green
There may be several causes to this problem.
1/ The lid of the printer needs to be firmly shut before the Red light changes to Green.
2/ If the ribbon has come to the end then the red light will come on, change the ribbon.
3/ If you have changed label size and not recalibrated the printer to the label then the RED will come on.
Any error within the printer will bring the RED light on.
You can download the 2844 User Manual from
http://www.lancerlabels.co.uk/2844user.pdf
Jan 16, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Error conditon ribbon out
if you are not using a ribbon you should configure your printer properties in direct thermal the same with your printer configuration in LCD Panel, if your printer properties is different with the LCD Panel error condition ribbon out will come out to your LCD Panel
Jul 27, 2008 | Zebra Z6M Plus Thermal Label Printer
Zebra 110Xi III Plus Thermal Printer Logo
979 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
