Compaq presario laptop
My son removed the spacebar key of my laptop and cut off the little rubber pad. Do I have to have the whoe keyboard replaced or is it possible to have a new rubber pad put on under the key? I am having to press on the bare circuit inorder to activate the spacebar and it is very annoying as it slows down my typing completely.
  • Nandakb May 01, 2008
    My son removed the CTRL key out of the laptop keyboard and it looks like the bracket that keeps the key intact has broken and is making the key comeout after couple of key presses. Can I get this bracket on the market? The laptop model is Acer Travelmate 4230.
    Problem Solver:
  • 14 Answers
Full keyboard replacement is recommended as the brackets to place the keys are not sold
Posted on Mar 24, 2008
Its the small rubber bit under the space bar
ok you need to unclip the spacebar carefully take off the rubber and replace with one from another keyboard use rubber solution to bond it in place making sure that the center on the board and rubber pad are free from dirt or glue, a good place to dource the rubber pad from is old mobile phone keypads or old childs toys with rubber buttons one of those cut to size and glued to under side of spacebar would be perfect, hope this helps and good luck.
Jun 21, 2013 | HP Mini 210-1030NR 10.1-Inch Black Netbook...
My compaq presario c500 laptop keyboard isn't
only one way change the keyboard with new one. or use ans extrnal usb keyboard
Feb 02, 2013 | Computers & Internet
The spacebar key has come off the keyboard on my compaq presario cq57. How do I put it back on please
Glue it with either Super Glue or apply Ados to both the key board side and the back side of the key and then press together after 5 minutes.
Jan 10, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
Compaq Presario V4000 laptop lower volume button (just to the right of the power on/off button) stays depressed. The button is concave now instead of convex. What to do?
Does the machine have regular keys (that remove) or a "blister switch" type key pad? Have you tried to use compressed air to remove any obstruction? OR try to pry the key, very gently, up? A LITTLE silicon spray? You may have to remove the keyboard. If you use the Tray Notification Area Sound Icon to increase volume what happens?
Dec 11, 2012 | Compaq Presario V4000 Notebook PC
Some of my keys on the keyboard don't want to work and I was told I need to replace it. But how do I remove my current keyboard on my Compaq Presario 2100 laptop?
You need to unscrew some of the screws on the bottom of your laptop. They may be under your battery, or under little rubber covers. It is likely but not gauranteed that the right screws will have little keyboard icons next to them, if not, guess, and then try to remove the keyboard, if it doesn't come off, remove another screw...etc.
Finally, when it comes off, there will be a bus (group of wires) connecting it to the motherboard. Wiggle the bus slowly and gently out of the port on the motherboard, and then wiggle the new bus of the new keyboard into the port and screw the new keyboard in.
The drivers should be installed automatically, and it should work right away.
Jul 05, 2011 | Compaq Armada 7400 Series Replacement...
My spacebar on my Dell Inspiron E5015 stopped working, so I pried up the cover to see what was wrong. There are three 'keys' inside the keyboard, but only one is raised the other two are flat. The...
Not 100% on your model laptop, but on some leptop keyboards only the middle unit acts as a spring to return the spacebar to its resting position. As far as replacement with house hold items, the only thing that comes to mind is trying a fat rubberband. Cut it so its a strip and double over a few bits to make a pad of sorts.
Best of luck.
May 23, 2011 | Computers & Internet
I dont know why is my key board is didn't work can you show me how to unlock my key board
restart your computer. on boot it will say press del for bios. do that. in case it enters the bios menu then keyboard is fine. probably some virus in windows. if not then your keyboard is damaged.
Mar 03, 2011 | Compaq Presario CQ60-220US PC Laptop
Spacebar came off;wont fix now.
I don't think it is worth messing around with it anymore..Look for a replacement on ebay..Unless you get another same model and remove the needed bits..
Jun 12, 2009 | Compaq Presario C700T Notebook
Spacebar key wont click back on
get a new keyboard...those springs that need to go under the keys if you loose them they never function the same.
Feb 14, 2009 | Compaq Presario C700T Notebook
Computers & Internet Logo
645 people viewed this question
David Payne
David Payne
