Question about Hotpoint Washing Machines
Where is the filter on a hotpoint aquarius wml520? the machine is spinnin for over an hour but the clothes are still drippin wet
  • 38 Answers
SOURCE: Hotpoint Aquarius WD440 Error
you will find your filter is blocked
Posted on Jul 26, 2007
  • 3 Answers
SOURCE: washes but does not spin
your brushes will be worn down and you can cange them you self just remember to unpug machine first remove back panel and 2 13mm motor fixing bolts disconect wiring and remove motor different brushes were used by hotpoint you will need to identify them good luck
Posted on May 14, 2009
  • 89 Answers
SOURCE: Where is the filter on the Hotpoint Aquarius
Filtet access at the rear of the machine behind access panel, Remeber to remove the plug from the socket before removing the rear panel
Posted on Jun 10, 2009
  • 82 Answers
SOURCE: hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Posted on Jun 28, 2009
  • 155 Answers
SOURCE: where is the filter on a hotpoint aquarius 1000
The filter is underneath the machine,tilt it backwards look underneath and
you will see a rubber pipe with a plastic inner with a clip on the end.
Undo the clip and slide the filter out.
Posted on Apr 06, 2010
Hotpoint Aqaurius WML520. No functions at all, motor does not spin, pump does not empty water out, none of the programs work.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 24, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
How do I remove the powder draw from the aquarius wml520, please?
1. Extend the dispenser drawer until the stop is reached.
2. Press the locking tab located in the centre rear of the drawer and pull the drawer out.
Mar 19, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Spin not working properly, sounds ok but clothes are too wet once complete and the independent spin cycle leaves clothes soaking!!!
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
Jan 25, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
621 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
