Question about Acer Aspire 4730-4947 Notebook
Unbooting issues mine is an aspire 4730z. Its comng that no bootable device found . Bt i can use it if i enter into dh BIOS and simply saved. wil it be prblm with my CMOS? or a pblm with hard disc? My BIOS is updated. if i restart while using, no prblm.bt after shuttng dwn and if i on it bootng pblm wl again arise. wl it cause any harm to my system if i use it by entering into BIOS. pls provde solution.
    Guru:
  • 324 Answers
Please have your BIOS setting updated, after this if this problem persists, have the CMOS battery replaced.
Posted on Apr 24, 2010
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Hii....mine is acer aspire 4730z lap the problem is that while switching it on am getting an error message as NO BOOTABLE DEVICE FOUND....INSERT BOOTABLE DISK AND PRESS ANY KEY.....but if i restart usng...
Run CHKDSK/F to fix any hard drive errors and then run a registry utility to clean the registry. www.iobit.com works very well and is FREE!
Hope that helps.
Feb 27, 2011 | Acer Computers & Internet
Vista wil not boot .. screen says no bootable device
Get into Bios and
1. check if the computer can "see" your hard disk,2. check if the bootable device is the hard disk.
If these options are ok and problem still exists maybe our hard disk is damaged or bad connected.
Oct 02, 2010 | Acer Aspire 7720 Notebook
I want to reset my bios aspire 4730z.. please help me... i want to downgrade my laptop from win7 to xp...when i refomat to xp blue screen appear and some saying error.. please help
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed). You can set the bios to default if needed.
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the installation disk, follow the prompts to press any key to boot from cd.
  8. When you get to the screen that shows the partitions you should delete all of them, and then create new one. format and install your os. I hope this helps you good luck
Sep 24, 2010 | Acer Aspire 4730-4947 Notebook
Unbooting issues
>> PXE ROM, check cable etc
>> "no bootable device found insert cd to boot from cd"
Your computer has a list of devices to _try_ to "boot" (start-up):
* 3.5' diskette
* USB device
* USB-connected external CD-ROM
* your C: drive
* the internal CD/DVD
* over the network, if your computer's network-port is connected to a network-accessible boot-server.
So, the error-message means that either:
* the "order" of devices _excludes_ your C: drive
* your C: drive is "dying" -- and does not _always_ respond
* the tiny battery on the computer's motherboard is "dying", and it's "forgetting" the BIOS settings, including the fact that the C: drive is available.
When you enter BIOS-setup, your computer "finds" your C: drive, and everything works fine, even when restarting.
So, first get a qualified technician to replace the battery on the motherboard.
>> my battery backup is decreasing
This is an _independent_ problem -- the battery is not recharging as quickly as when it was new, and it does not hold a charge for as long as it does when it was new. Replace it, if you need to frequently use the computer via battery-power.
Apr 23, 2010 | Acer Aspire 5610-4648 Notebook
Acer aspire 4730z bluetooth problem
Yes your Machine got WPAN: Bluetooth® 2.0+EDR (Enhanced Data Rate).
If its not working then you need the drivers, you can download them free here
If you problem was solved, Kindly do Rate!
Jul 31, 2009 | Sony MEX-BT2500 CD Player
Lost sound on aspire 4730z suddenly
right click my computer
Hardware Tab
Load up Device Manager
Find the sound device
Right Click
Uninstall Driver
Restart Computer
Go Here and get the driver http://gd.panam.acer.com/home/
(Notebook , Aspire , Aspire 4730Z , Select Windows Xp From Drop Down Menu and then Drivers will show
Reinstall Driver
Restart Computer
If you found this helpful , please rate my solution below
Kind Regards
1234s282
Jul 02, 2009 | Acer Aspire 4720 Notebook
When I restart my computer (vista) it does not reboot with my external hard drives plugged in.
Most likely your BIOS is set to search for bootable external drives/devices. This causes the computer to pause indefinitely.
To fix this, you will need to change your BIOS boot settings.
It is simple enough and danger free so long as you make sure you keep your harddrive as a bootable device.
To fix:
1> Enter the BIOS by restarting the computer and waiting for a display to show up before windows starts - it will either be a graphical display or text, but should say "press F8" to enter BIOS. I use F8 merely as an example, as that is what mine uses - it can be different for you.
1.1>If you cannot see it quickly enough, simply press the "Pause" button on the keyboard - this will cause the boot process to stop until you press another key, and will allow you to see which key is required to be pressed to enter the BIOS.
2> Since I do not know what BIOS or motherboard you are using, I cannot give exact names for what you will need to navigate to in order to find the settings, but in general it will be BIOS Features, Advanced BIOS features, etc.
2.1*> In Award BIOS it will be under Advanced BIOS Features.
2.2*> Whatever category they fall under, they will be named something like "First boot device" "Second boot device" "Third boot device" etc, and possibly "Boot Other Device" or "LAN BOOT" etc.
2.3> Once you have found these settings, DO NOT change the setting which has a value of "Hard drive" or "HDD." If it has settings named "Boot from USB" "Boot Other Device" or something along the lines of "Third boot device: USB" then you should disable those. Anything relating to Boot and which are not CD/DVD or HDD/hard disk should be set to "Disabled" or "None."
2.4*> These changes can be reversed any time, and any mistakes with the booting priority can be fixed by simply reversing the settings (the BIOS will probably allow you to set everything to Default and that ought to fix it if anything is messed uo as well.)
3> Hit Esc to get out of the category and navigate over to "Save and Exit Setup." This will save the changes and restart the computer.
4> Your problem should be fixed, and USB devices plugged in during reboot should not effect the boot process. However, if the problem continues, please reply that it did not work and I will move on to the next possibility.
3>
Dec 14, 2008 | Western Digital My Book Essential Edition...
Acer Aspire 4730-4947 Notebook Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
