Question about Dishwashers
Glasses look filmy and fingerprints are still evident after even Pots & Pans cycle and sani-rinse.
    President:
  • 949 Answers
It sounds like you have a serious wash problem. A couple things to check.
Be sure you are using fresh detergent. Old dish washing detergent looses its power and will not work. Be sure to use a name brand like Electrosol or Cascade they both contain the chemicals need to dissolve and clean properly. Use more detergent if you have hard water or use an additive such as lemi shine or glass magic to boost the water softness.
Try running the hot water faucet at your kitchen sink unit hot prior to starting the dishwasher this will help with the thermal energy needed to clean.,
If you still have trouble send me your complete model number from the tag on the tub so I can help trouble shoot the machine better.
Posted on Apr 25, 2010
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
LG Inverter Direct Drive, at the end of the cycle there is a grey -white residue on everything, interior,glasses,pots n pans. We use Cascade packets and Rinse-aid. Please help!!
The packets usually have detergent and rinse aid together, built in. If you also have liquid rinse aid in the automatic dispenser, you are getting a double dose, and that is causing the film. Use standard dishwasher detergent until the automatic rinse aid dispenser is empty, or at least turn the pointer indicator (located by the rinse agent filler) to the lowest setting possible to help somewhat.
Mar 05, 2011 | LG LDS4821ST Stainless Steel 24 in....
Is our dishwasher no good? We have hard H20 and practically rinse clean our dishes, untensils & glasses before we load it. We never use it for pots & pans. There's a sort of soap scum on the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Nov 28, 2010 | Maytag Dishwasher
Brand new dishwasher does nothing but wash & rinse
Time for warranty replacement or repairs! Good luck!
May 14, 2010 | Frigidaire PLD4375RFC Dishwasher
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Dishwashers Logo
190 people viewed this question
Top Dishwashers Experts
