Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Door has locked and won't unlock - Hotpoint Aquarius WD63 Front Load Washer/Dryer
  • 3 Answers
Turn the machine off from the mains leave for a few mins then turn back on might help
Posted on Apr 25, 2010
Nissan 1990 pathfinder doors won't unlock
Door locks are powered through a circuit breaker (location not indicated) which applies 12V to the door lock timer. Insertion of the key causes the door lock actuator to unlock the door ...unless the timer prevents it. It is doubtful that all the doors could have failed lock components
Oct 15, 2012 | 1990 Nissan Pathfinder
1998 honda civic rear door handles work but lock won't unlock
THERE IS A CLIP ON THE INSIDE OF THE DOOR ON METAL ROD THAT GOES TO THE LOCK MAKE SURE ITS NOT DAMAGE OR FALLEN OF WHERE THE ROD GOES TO THE LOCK THERE ARE 2 ROD ONE OPENS THE DOOR THE OTHER ONE LOCKS THE DOOR
Sep 09, 2012 | 1998 Honda Civic
All my remotes won't unlock passenger doors, why?
this is a problem that can appear after your car battery died, cause the car didn't reset propely, so taking the battery out and putting it back in or letting your car die again would do the trick. I tried a lot of reprogramming procedured for my remote key, none of them worked, what did the trick though was simply unlocking the doors via the all door unlock button on the passenger side door, so simple.
Apr 27, 2012 | Cars & Trucks
The doors will not lock or unlock from the door but will from the remote?
The title suggest the door won't unlock unless the remote is used but during the summer it was the inverse. If while inside the car the doors will not lock or unlock from the door but will from the remote then you have a faulty switch.If while outside the car the key turns while in the lock but the door won't lock or unlock then the linkage at the end of the lock is faulty. You'll need to remove the door inside plate to check this.
Dec 07, 2011 | 2004 Infiniti FX45
2003 Monte Carlo SS, FOBS won't unlock doors (new batterries), use key and open the door with the door open FOB will lock and unlock the door, shut the door and the FOB won't lock the doors. After...
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Aug 17, 2011 | 2003 Chevrolet Monte Carlo
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
2006 chev.colora the door lock on the front right side won`t work
Common for the door lock solenoid to go bad and your going to need to replace it. You may hear it clicking but it's to weak for it to lock and unlock the door.
Thank you for using fixya and good luck
Apr 26, 2010 | 2006 Chevrolet Colorado
Passenger sliding door doesn´t unlock (Power locks). When pulling the handle either inside or outside with doors unlocked it won´t open.
Sound like you have a dammaged door latch assembly. It is a pain but you have to take the insid door trim panal off to see what you are doing and make sure the latch assy is un locking. Dis connect power door lock motor linkage to make sure motot is not jaming the lock in the lock possition.
Oct 07, 2009 | Ford Windstar Cars & Trucks
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
74 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
