Question about Sharp EL-6810
PDA Sharp EL-6810 has some of its keys frozen
My PDA Sharp EL-6810 has some of its keys somewhat frozen. I must keep on pressing then until get some result. I think that the key contacts are dirty. Is it possible to open the PDA to clean it? How can I do this? Tks Dativo Marques
2 Suggested Answers
dativo
SOURCE: Sharp EL-6810 - Keys frozen
Sirs, I am confused with your proposal. It seems that you offered me to join a paid assistance if I still have the problem and, in case I have solved it, I would be passing you the solution? Am I right? Well, if you are going to charge me to help, how much you would pay me to pass the solution? Thanks. Dativo Marques
Posted on Sep 30, 2008
All my answers come in decimals on my sharp el-531x and i want to turn it to normal
Press the SETUP key, press 0 for FSE, press the down arrow key, and choose 3 for norm 1. The calculator should return to normal. If all else fails, there is a reset button on the back.
Dec 08, 2013 | Sharp el-531x scientific calculator
HOW DO SET TAX RATE ON SHARP ELSI MATE EL-2125
Easy. Press M- key [has RATE SET] above it. This will shown your current setting say 17.5. Amend to 20.0 and Press M- key again. Rate should now be set at 20%.
Test by entering:
100 and pressing +TAX key - Answer should be 20.
100 and pressing -TAX Key - Answer should be 83.33
Jan 04, 2011 | Sharp EL-330AB Calculator
Were can i get a copy of the manual for sharp pda el-6800
Please select the below link to download your manual for sharp pda el-6800.
http://www.devicemanuals.com/guide/PDA/Sharp/Sharp-Memomaster-Organizer-EL-6800-Operation-TWpVNU1qYz.html
Before downloading Please input validate code for download.
Thanks and Regards
Anand Sachan
Oct 28, 2010 | Computers & Internet
How do you change date and time on Sharp EL 1750Piii
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 27, 2010 | Sharp EL-1750PIII Calculator
What button do i press if i want to write something in degrees ? its in the trig chapter i have a sharp El-531w Thanks
To set the angle unit to degree you press the [DRG] key once or twice until a DEG indicator appears on the screen (where you cannot enter anything).
The key may be labeled [DRG] with an arrow sign.
Hope it helps.
Thank you using FixYa and for rating the solution.
Nov 30, 2009 | Sharp EL-531VB Calculator
How do I print a date format with sharp el 1801PIII?
To print the current date press once the Clock/Calendar key and then press once the Non Add/ Subtotal key (# key)
To print out any other date (or codes and other numbers that are not part of a calculation) just type it and then press the Non Add/ Subtotal key (# key). The date/number will be printed preceded by the # sign.
You may also want to download the SHARP EPL-1801PIII Operation Manual
Jun 04, 2009 | Sharp EL-1801P Calculator
How do I set the date and time on my EL-1801V calculator?
Push the button at the top over from GT to SET.
type the date in using the decimal as a spacer.
Then press the date/time key.
for the time...
Press the date/time key until the date shows,
then enter the time in military time and press the date/time key again.
Dec 01, 2008 | Sharp EL-2630P Calculator
Sep 27, 2008 | Sharp EL-6810
Sharp EL-6810 Logo
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
