Question about Hayward Phantom Pool Cleaner Complete with Booster Pump
Phanton pool sweep just turns in a circle upside down
  • 640 Answers
This definitely sounds like an issue with the pool cleaners hose. Look for a bend or kink near the connection between the hose and cleaner. If you notice one, try stretching the hose on a flat surface in the sun for several hours. If this doesnt work, you will probably have to replace the hose.
Posted on May 25, 2011
Why does my pool sweep go around in circles on one wheel and not pick up anything in a week?
make sure the ballast ball doesn't have any water in it if so replace also make sure little exhaust on back is pointed at 11 o clock
Mar 31, 2016 | Polaris VacSweep 280 Pool Cleaner with...
What would cause the 3900 to run but the tail does not move?
Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
Jun 24, 2011 | Polaris 3900 Sport Pool Cleaner ()
The sweep tail doesnt sweep
Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. You might also need to adjust the screw that holds the sweep hose in place. If it is too tight it will not have the slack to move. If it is too loose, it will not have enough tension to move. Try adjusting it and it should have the pool cleaners sweep hose motion.
Mar 14, 2011 | Pentair White/Gray Legend Platinum...
Polaris 380 sweep hose isn't moving -- i have checked the sweep hose adjustment screw and it does't make a difference. the polaris unit is moving and vacuuming and there is water going through the sweep...
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Jan 10, 2011 | Polaris 380 In Ground Pool Cleaner
My phantom spins in circles and goes upside down what could be my problem?
It is is going in circles, it is likely a bent hose. This is common with these pool cleaners if you store your hose in a coiled position. Try laying the hose out on a sunny day and leave it there a few hours to straighten the hose. The running on the side could be a result of the debris bag being too full and heavy. The pressure could also be too high, which would cause both of these problems. Try decreasing the water flow though your cleaner.
Sep 24, 2010 | Hayward Phantom Pool Cleaner Complete with...
What causes the Phanton to go into a spin after about 10 min of working correctly?
Spinning in the Phantom pool cleaners is usually cause by a problem with the hose. Check the base of the hose near the cleaner for a bend or kink (anything unusual). To correct, you can lay the hose stretched out on the lawn in the sun for several hours. In extreme cases, you might have to replace the hose. Make sure that you are storing the pool cleaners hose in a non-coiled position.
Jul 01, 2010 | Hayward Phantom Pool Cleaner Complete with...
Pool sweep wheels are not turning
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
May 19, 2010 | Polaris 280 In - Ground Pool Cleaner with...
280 sweep hose does not sweep-drags behind unit-unit works fine-cleans pool
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Apr 27, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Hayward Phantom Pool Cleaner Complete with Booster Pump Logo
193 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
