Question about Xerox DocuColor 12 Printer
My copier machine os showing error e602-001.what
My copier machine is showing error e602-001.what to do?
MFC465CN-PAPER JAM- NONE IN MACH.CANT USE
Sir/Madam
MAKE SURE YOUR BROTHER MACHINE IS THE DEFAULT PRINTER
If the printer driver is not set as "default printer", you can not print. Make sure your Brother machine is set as default printer. If your brother machine is not set as default printer, set it as default printer.
  1. Click Apple Menu and choose System preferences..., click Print & Fax, Print & Scan or Printers & Scanners.
  2. Choose from pull down menu of "default printer".
DELETE ALL PRINTER JOBS
  1. Click Apple Menu and choose System preferences....
2 Click Print & Fax, Print & Scan or Printers & Scanners.
For Mac OS X 10.5 - 10.7 users
Choose the print job (1) and click Delete (2).
CHECK THE PRINTER STATUS
Choose brother machine's icon and click "Open Print Queue..." then check the printer status.
The Resume or Resume printer icon which is surrounded by red lines is displayed in printing when the printer is out of paper or the printer is turned off and on. Click Resume or Resume printer.
For Mac OS X 10.8 or later users
If you connect the brother printer via USB cable, the error message The printer is not connected or Offline is displayed on Print Queue when the USB cable is disconnected or the brother printer is turned off. Connect the USB cable and turn the brother machine on.
If the other error message is displayed on Print Queue, check if the LCD display or LED indication of your Brother machine is not showing some error. If an error is displayed, go to the Troubleshooting section and find a solution.
REGISTER THE PRINTER ICON AGAIN
  1. Choose your printer icon.
  2. Click [-] button to delete the printer icon.
  1. Click [+] button to register the printer icon again.
In spite of if you click [+] button, the brother machine is not displayed, then the brother machine is not recognized.
If you use the printer via USB connection, reconnect the USB cable or restart the Macintosh or your brother machine.
For Mac OS X 10.4 users
I Suggest You Go To Official Brother Printer Website For Brother Printer Troubleshoot:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000046/faq002646_001.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Or
If You still having Problem Then Follow Us For Brother Printer Support
Jan 23, 2014 | Brother MFC 420CN All-In-One InkJet...
7310 All In One - running windows 7 64k OS problem: error blinking msg: error remove and check color cartridge. This is a fairly new cartridge, I have removed color cartridge rubbed it on a damp cloth -...
you need to change it, maybe you damaged it while trying to get it working. the clearly shows a faulty cartridge remember it can be faulty even as new or from the box
Oct 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
After initializing it is showing 0A error
first your system windows has currupted
get the fresh install the os
and then install again
the problem has solved
because your system has effected for viruses
than epson dfx -9000 matrix printer showing error
Apr 29, 2009 | Epson DFX-9000 Matrix Printer
I have canon ir2016 copier When i on the machine the screen appers or error DOWNLAOD STANDBY. Solution to solve it. thanks. japhet.
Hey, If your machine stops the starting sequence as regular but then it shows the download message the only solution you can try is to reinstall the operating system to the copier.
you will need the correct operating system, a laptop computer, a cross ethernet cable and ready to proceed. the bad news is that the OS is only given to canon authorized service centers, so in other words you are gonna have to call them. sorry.
if that doesnt work out then you may have to buy new pcb boards.
Jan 23, 2009 | Office Equipment & Supplies
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Error E061 & 0070
rewire your corona and change your grid if the error still presis change your drum
Oct 04, 2008 | Canon CLC 1120 Color Copier
System Error E000
My computer is showing system error E000. I can not do anything at all with the computer. Please tell me how to fix it.
Jul 07, 2008 | Office Equipment & Supplies
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
Xerox DocuColor 12 Printer Logo
18 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
