Question about Crown XLS 602 2-Channel Amplifier
What is the brand of the potentiometers, one is broke...i'd like to replace it.
  • Crown Master
  • 5,126 Answers
Potentiometers don't really have a brand as such. To replace one you go on ohm range (most often marked on it). The next thing is size and getting it to fit.
You can look around any parts shop once you know it's value in ohms.
One thing I can tell you if you can hold of the service manual it will give you the ohm value and quite possibly a part number. This could help you track down the exact part. Two more things! I believe that Crown are connected with Hitachi. Also from an old spares guide that KEY ELECTRONICS deals with Crown parts. I couldn't tell you if Key still operates though.
Posted on Apr 24, 2010
My precor elliptical keeps giving me error44
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Jun 26, 2014 | Precor EFX 546i Elliptical Version 4
Error 44
Corrective Action
Nov 27, 2013 | Precor Exercise & Fitness
Error 44 precor eliptical 546
Corrective Action
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
C956i Precor is displaying Error code 44 ?
Corrective Action
May 30, 2012 | Precor C956i Treadmills with HR /...
The loudness knob has suddenly stopped working. The knob just spins, won't turn on the receiver at all. Any ideas?
The knobs are usually connected to a potentiometer; basically a variable resistor circuit with a long shaft that the knob attaches to. The knob could be secured to the shaft with a plastic grommet, which can be stripped. It could be attached by a small screw on the knob, and tightening that would fix it. Or, it's possible that the potentiometer itself broke, and would need to be replaced.
If the "pot" is broken, a repair shop should be able to fix it for less than $50. If you're handy with tools, you can take the 7100A apart; hopefully read the specs from the potentiometer; and buy a new one. Replacing it shouldn't take more than a few screwdrivers, some pliers, and a soldering iron...
Feb 06, 2011 | Sherwood 7100A Receiver
I have a C956 treadmill. I am getting error code 44, can you tell me what that means?
Corrective Action
Jan 04, 2011 | Precor C956 Treadmill with Cardio Theater...
We broke the control lever that allows the scooter to go frontward and backward. What is the part and how can we get it.
The Golden Buzzaround Lite Scooter (I am not sure of the RTO prefix) is manufactured by
Golden technologies. If you broke the control lever (paddle) for the throttle potentiometer, there is probably also damage to the potentiometer. I recommend you replace the paddle and potentiometer. See page 16 at the following link:
http://www.goldentech.com/pdf/support/ride/gb101-service-manual.pdf
This is a simple repair that should take under 1 hour. It's a little tricky to center the paddle by loosening and tightening the allen set screws.
Please purchase OEM parts for this scooter to get the correct parts and fit. Please consult the manufacturer:
Golden Technologies • 401 Bridge Street, Old Forge PA 18518 • Tel: (800) 624-6374 • Fax: (800) 628-5165 • www.goldentech.com
They may require you to purchase from an authorized local dealer.
A partial parts list is available at this link:
http://www.goldentech.com/pdf/support/ride/BuzzaroundParts.pdf
You can save considerably on the labor cost if you replace this part yourself. Work slowly and carefully so you do not damage the internal circuit board or pinch any wires on assembly. Use the correct size allen wrench so you do not strip the screws when removing the paddle lever. Hope this helps.
Nov 26, 2010 | RTO Golden Buzzaround Lite Scooter Meets...
I have a old NAD 1300 pre amp. I need to replace the volume rheostat where can i buy the part?
Hi, for the price of servisol you may as well buy a brand new pot. The nad uses a dual carbon pot. Any electronics shop should have one.
Is it a pcb mounted type or one with loot solder tags?
A couple of quid, but if you want to upgrade, then spend around a tenner and get an alps conductive plastic pot.
Try this:-
http://www.rapidonline.com/sku/Electronic-Components/Resistors-Potentiometer/Control-Potentiometers/Professional-audio-potentiometer/65228/66-0225
OR:-
http://www.maplin.co.uk/Module.aspx?moduleno=2207
Have a look on ebay, there should be loads.
Just found this mod.
http://www.diyaudio.com/forums/attachments/solid-state/69062-replacing-nad-1300-volume-balance-pot-nadmods.jpg
If you need more help, give us a shout and i'll try harder :)
Regards - Anthony
Feb 11, 2010 | NAD C320 2-Channel Amplifier
The potentiometer knob broke
Do you mean the steam knob? if so you have to take a screw driver between the chassis and the knob, then you do a ****. There are some kind of glue on it.
Jun 10, 2008 | Saeco Magic Roma
I need a component?
IS whether only the KNOB get broked or the WHOLE speaker got worsed...
If ur control KNOB only got damaged, then try to OPEN the speaker, and find the VALUE of the POTENTIOMETER... u can get the control from any ELECTRONICS BAZAAR or in any electronic spares shop...
then FIX it...
Dec 12, 2007 | Logitech X-530 Computer Speakers
Crown XLS 602 2-Channel Amplifier Logo
73 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
