Question about Video Game Consoles & Games
Having two problems... 1. error 80010514. I fixed that I believe by holding down power button, waiting for 3 beeps and then restoring my data files. 2. Now I still am having problems getting my games and staying online during games when I do get on. I also placed in a different game. The game needed an update and I got Error 80028F08 Game System: PS3
  • 13,433 Answers
Hello
the error code indicates a hardware issue with either the blue ray drive or the hard drive or possibly the mainboard of the unit.
One of those components is the issue, the drives are the ones that wear out eventually, so the motherboard would be the less likely problem.
problem could also be a dirty disc, or the laser lens in the drive is dirty, or possibly out of focus.
Are you in warranty? I would insist that you send this in for warranty repairs at sony. If you are outside of warranty the repairs are 150$.
Posted on Apr 24, 2010
  • Ekse Apr 24, 2010
    since you previously had 80010514 which points to a hardware problem, the hard drive might be going out. But if that doesn't keep coming up anymore, make sure your discs are clean, you could buy one of those blue ray lens cleaner for your ps3 and see if it helps.
Error code on ps3......will load regular dvds but not games or blu-rays.....code 80010514 pops up
that error is caused by a bad section on your hard drive or a bad installation of firmware, the first problem also causes the later so its usually both. you can fix this problem by formating the hard drive and reinstalling the firmware, but you will lose all your data and saves this way unless you back them up. you can however fix this another way, by accessing the play station's recovery console.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the Playstation System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the Playstation.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the Playstiation System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
if you chose restore file system just follow the prompts and your blue ray drive should work again.
Jun 12, 2011 | Video Game Consoles & Games
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
Error code 80010514 prevents the console form reading and playing discs
Assuming the hardware isn't dead and its just a software problem you can try to restore it with these steps:
Hold the power button down so the system will turn on and turn off once again.
Once that happens press and hold the power button again. It will beep once as it turns on and then it will beep twice. Take your finger off immediately after the double beep. If the system turns off accidentally or starts up normally try again.
You will be prompted to plug in your controller via USB and then hit the PlayStation Home button
Choose the Third option "Restore File System: Checks for corrupt/missing system files."
After that your system should attempt to restore and/or reinstall any missing software that may be corrupting its function.
Feb 11, 2011 | Sony Playstation 3 (PS3) Console
1. Restart System: Restarts the PLAYSTATION®3 System.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
6. System Update: Update the PLAYSTATION®3 System
After this, it is going to restart and bring up a screen reading something like "you have Corrupted System Data. Your PS will now replace this data" Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that's stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive.
However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren't corrupted) back to the flash memory which is corrupted thus fixing the problem
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
My son can't play games the console is giving an error message of (80010514) Please can you advise what this means?
Sorry, the above post should of been a solution!!
This basically means that the firmware (the PS3's set of instructions for how to work) has become corrupt. I will give you something to try but if it does not work I am afraid you will have to try and contact Sony. Try these steps first but be warned, make a backup first of all your data!!
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep 5 seconds later then beep once more and turn off. Release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. As soon as you hear these 2 beeps let go of the power button.
Step 4. The PS3 will start up and ask you to connect a controller via USB and press the PS button. Do this and then move onto the next step.
Step 5. The PS3 will display a menu, 1-6. Choose option 3. Restore File system. This will check for missing/corrupt files. It may possibly report that the hard disk is corrupt and needs to be formatted. I must warn you that you may lose some data at this step, namely save games.
Step 6. Wait for the PS3 to restart and try playing a game again.
Hopefully this will cure the error but unfortunately it is such a rare one most people who do get it never manage to fix it 100%. For some reason the error just keeps coming back. If the error does not go away then I am afraid you will have to give Sony a call and see what they say. I hope this helps.
Thank you for using FixYa
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
PS3 error code 8001050f-80010514 and 80028f22,, I took a blueray eye out of a working PS3 to test, it can now see the disk, but will frezzup if i try to play it.
This all error codes can be reset by the procedure.But if the lens is removed and there is a freezing problem then its a problem of lens alignment or the lens spinning motor is got loose or weak check it. click this link for the reset procedure:--For this errors. http://www.youtube.com/watch?v=1CJ9Q8bG-0s&feature=player_embedded -------- But if there is lens alignment or lens motor problem then it needs to be checked and repaired to resolved the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 29, 2010 | Video Game Consoles & Games
Ps3 error code 80010514
This is alot of info but you wanted to know. :P hope it helps
Gamerevolver.com recently had an interesting article regarding the dreaded 80010514 error. I hope many of my loyal visitors never have to encounter it. Their is a known issue with the PS3, simply known as error 800010514 which doesn’t happen often but when it does, it’s darn right nasty.
The error in question is mainly seen within the first month of use, or to put it bluntly, it has the error right out of the box, however, we have seen this occur at almost a year into service as well.
“An error occurred during the start operation. 80010514′
Gamerevolver.com recently ran into the the dreaded 80010514 error shortly after installing a new game they had purchased off the PlayStation Store and decided to document it. Here is what the have to say…
Since this error occurred, we obviously contacted Sony Support. We were informed that the code is not common, and a simple reset of the system, and restoral of factory settings should do the trick. Unfortunately, after the restoral, the error still occurred.
The error code is actually one of two things, a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware, both iterations actually coincide with eachother. If the hard drive suffers a faulty sector ( a section of damaged space on the drive that data may have been written to that no longer is readable), an installation may still be processed, and even work, but the error can cause some serious side effects, such as option b. If your PS3 has installed an item incorrectly, including firmware, it is in high risk of receiving this error.
Basically, what is occuring is the corruption of game disc recognition and execution. If you will notice, in 90% of all cases, the drive will still play DVD and even Blu Ray movies with no problems. When trying to start a game however, the title, sooner or later, will receive the error.
1) Ensure that your internet connection is stable. If you are using a wireless connection, make sure your signal is at least a solid 80%. If not, make the proper adjustments until it is.
2) Dust your machine regularly. Any PS3 owner will tell you that the Playstation 3 is a dust magnet. Just run a dry cloth over it every couple days, and you should be fine. This will help prevent heat issues and shorts that may occur.
3) When installing firmware and/or software, make sure you follow the instructions. Even if you have installed 6 versions prior, each one is different, and may require additional steps. Save yourself the headache and just follow them, it only takes a minute or so longer to do it right.
Lets sum it all up, the error is not hardware related and is caused due to corruption of firmware. Restoring you PS3 will not roll back the firmware, and unfortunately will not fix the issue 9 times out of 10. If you are receiving this error, contact Sony for a replacement unit. Again I hope none of my readers have to see the dreaded 80010514 error and by following Gamerevolver.com’s simple steps your bound to prolongue the life of your PS3 indefinitely.
(Update) Eurogamer.net contacted a SCE UK spokesperson which told them “”I’ve spoken to our Customer Services department and they aren’t aware of this issue with the PS3.” So take that as you will? Is the dreaded 80010514 just a myth? or an error that Sony is not aware of?
(Update 2) Try this before replacing Blu Ray drive (Last Resort)
Undertakerza updated a game, Warhawk and his system froze, got it rebooted it could no longer access any discs (cd, dvd, blu ray, games) he was ejecting and re inserting disks when I realized that the drive wasn’t making any noise and also … not spinning disks anymore they come out the exact same way he put them in.
Here is how he did it:
Ok so I’ve fixed my issue. I will run through what you will need to do to fix yours if you are having issues with the blu-ray drive and general PS3 system operations like the XMediaBar this is totally worth a shot … I doubt this will fix any other issue. If not then your blu-ray drive/ PS3 is probably dead and needs replacement via the method listed above or by sony.
If you can, I suggest you back up your PS3 first. The menu that you will access to can fully erase your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”.
You access it by
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory which is corrupted thus fixing the problem
UPDATE: With the new firmware 3.10 you may be able to report the error code directly to Sony via your PS3 console. Have a look here, please note that this has not been tested for this error code yet.
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
Error code 80010514 been playing modern warfare all day and now it has threw up this error code and is not letting me play i have tried restoring file settings but nothing i just had a new laser fitted 2...
You need to RESTORE FILE SYSTEM to correct that.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 18, 2010 | Sony Playstation 3 (PS3) Console
Just set my boys pse up put a game in and error
take a look at this site it help me fix mine
http://www.ps3blog.co.za/2008/04/10/ps3-error-80010514-explained/
You access it by
Dec 25, 2009 | Sony Playstation 3 (PS3) Console
It says error occurred during the start operation(80010514)...anything I can do at all?
You access it by
Mar 23, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
97 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
