Question about KitchenAid Architect® KEMS308S Electric Oven
The oven door on our kitchenaid superba oven/microwave combo
The oven door on one side has come off the hinge leg. I was pulling the unit out to check the electrical connection and used the oven door to pull the unit out enough to gain access to the box, I must have pulled unevenly as one side of the door pulled out of its slot and I can't figure out how to get it back in again. help please.
    President:
  • 949 Answers
There are two versions of this hinge depending on the rest of your model will tell which you have.
Which ever one you have you will have to grasp the hinge and 'open' it, you may be able to do this by opening the door with the hinge partially in the slot it goes. Then either rotate the latch for hinge 1 or insert a pin for hinge 2 into the hole. You can use a short screw in place of the pin, just do not use one too long that comes in contact with the door liner.
Once the hinge is pinned it should be stable enough to lift the front of the door while putting into place.
If you need more instruction let me know.
The first here:
the oven door on our kitchenaid superba oven/micro - 8c8d7a8.jpg
The second is the older style
Posted on Apr 24, 2010
I have a kitchenaid KEMc308 Superba Electric oven and micowave combo. Just had the light &door spring replace. Now, it gives code F2 E0 for 60 second and then give code F2 E1. I checked the key...
If you're searching for an obsolete keypad for a Kitchenaid Oven/Microwave unit, FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order.
Feb 02, 2015 | KitchenAid Ovens
Model KEBC277 Kitchenaid oven - I need to remove the upper door, but can't figure out how to unlatch the hinge
there will be two hinge latches that you flip to stop the door from closing. This will allow you to push the door in and then pull out the bottom. I do not suggenst using the handle as it may cause damage. use one hand on either side of the door, push the door shut and then lift up a bit and pull the hinges out of the holes.
Oct 26, 2011 | Ovens
I need to replace the hinges on my kitchenaid superba, how do i take the door off ?
Usually all you have to do is open the door slightly, and lift upwards keeping your fingers away from the hinges as they have a very strong spring and can hurt if they release.
Jan 04, 2011 | Ovens
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
Sep 15, 2009 | KitchenAid KEBC107 Electric Single Oven
My kitchenaid superba oven door..
Contact the landlord and have him repair or replace the oven.
Aug 24, 2017 | KitchenAid Ovens
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Architect® KEMS308S Electric Oven Logo
356 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
