I have this machine Canon IR 7105 B&W
and it gave this Error Code E000578-8001
what do you think it might be?
  • 1,326 Answers
Odds are is that the finishers exit bins got stuck while looking for it's HP. Most of the time it is a garbage can.... Move the object blocking the path of the exit trays first. Then turn the power switch for the finisher off first then turn the main power switch on the right side of the copier. Once it is all off > turn the finisher back ON first then the copier and then remove the paper jams.... Good Luck
Posted on Apr 25, 2010
Ir 7105 black copy is appear
I've had the Laser go bad on two occasions causing black or partial black copies
Feb 07, 2015 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon ir 7086 error e012
DRUM MOTOR OR SOLID WAST IN DRUM UNIT (PROCESSING UNIT)....OR DISCONNECT AND CONNECT ALL DC CONTROLER JACS
Apr 15, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon ir7105 error codes 000602
TRy this link. Reading similar errors, similar machine = hard drive error. can ir7200 602 001 Archive Copytechnet com
Apr 09, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Error code e121
Reader controler cooling fan fault replace the fan or dc board
Jul 17, 2013 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon IR 7095, error code E000005-010
Hello to all
I have a client server ir Pass has forgotten his password and I reset.
how reinitialiser server S2 canon ir Pass?
Thank you for the help.
Dec 27, 2012 | Canon Imagepass S2 Fiery For Ir...
It shows code 246 canon ir 2016
I think this is a strange error code. Let me help youWhat is the last activity that you carried out on the machine ? Did you try reseting the machine in service mode? If not do the following Press Additional function,2,8,Additional function Use < or > keys to scroll & select CLEAR. Press OK Use < or > keys to scroll & select ALL. Press OK. Now switch off the machine & switch on. Did this solve your problem.
Apr 18, 2011 | Canon iR 2016i Black and White Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir 3300 machine error code 0064, plz suggest
CLEAN THE DUST & WASTAGE INK ON TRANSFER CARONA IN MACHINE & RESTART IT .
Dec 20, 2010 | Canon imageRUNNER 400S Copier
We have a Canon IR-7105 which keeps jamming , then codes out with code Error E000069-00000 (the tech was just in and did a PM)
it is a transfer corona problem ,clean it first.even its not ok change the corona wires.
if its not ok finally change the transfer corona .
Jan 21, 2009 | Canon imageRUNNER 7200 Copier
Canon iR 7105
The Tray A Area Sensor Unit may be faulty. Replace the Sensor
Oct 27, 2008 | Canon imageRUNNER 7200 Copier
589 people viewed this question
jasbo
jasbo
