Question about GE JVM2070 Microwave Oven
Fuse blown How long shoud I wait after the microwave is unplugged to remove the cover---to avoid electric potential?
    President:
  • 2,468 Answers
Most have a resistor in parallel with the hi voltage capacitor,but always use an insulated screw driver to double check and discharge the cap to be on the safe side,but normally with in 30 minutes
Posted on Apr 24, 2010
My microwave is not heating anything. I tried different heating buttons, is unplugged it and replied it and nothing worked. This unit is about 3 1\2 yes old. Any ideas? Thanks
I am assuming that the microwave comes on and the timer starts? If this is the case then the 'magnatron' (the actual microwave emitting bit) has stopped working. It could be as simple as a blown fuse, a blown rectifier diode or the magnatron unit itself. If you want to have a go yourself, wait at LEAST half an hour after turning off and disconnecting the unit before you take the cover off to check anything. BE AWARE THAT THERE ARE VERY HIGH VOLTAGES BEING GENERATED. Without electrical knowledge and equipment just check the basics
May 07, 2018 | Microwave Ovens
My Intellichef microwave model #K0936 has stopped working. I've tried different outlets but the microwave is not responding. Is there an internal fuse that has blown or is the microwave dead?
If the fuse is blown the microwave will be "dead". The fuse is accessed by removing the cover. You can usually find the fuse by following the power cord into the microwave. Unplug the microwave and don't touch anything except the fuse as the capacitor can hold an electrical charge.
Nov 02, 2017 | Microwave Ovens
How do i replace blown fuse in sharp microwave mdl 4A59
Remove the outer cover but be aware that doing so exposes you to dangerous, potentially lethal, voltages even with power removed. Find the fuse and replace it with one known to be good. Reinstall the outer cover and test.
Nov 10, 2016 | Sharp Microwave Ovens
Model 1880LS. How do I replace the fuse?
You will have to remove the outer cover. You should be aware that doing so exposes you to potentially lethal voltages, even with power disconnected.
Dec 24, 2015 | Sharp Microwave Ovens
My microwave does not heat up food. It now makes a loud sound when turned on. The fan and light work though. I have a Kenmore 665.60652000
if its under warranty just bring it back to the store or in the authorized service center. if not try this simple steps before you call a local repairman. unplug the unit from the wall socket. to avoid electric shock wait for a day before you proceed to steps two.... unscrew the unit to remove the protective cover. check if the high voltage fuse is okay. if not. check the high voltage capacitor and the magnetron.... ty
Jun 23, 2011 | Microwave Ovens
It's completely dead?? Not sure what happened. Power supply is fine.
Microwaves that suddenly loose power could have many causes with the easiest being a blown fuse inside the cabinet of the oven. To check for this unplug the unit and remove the screws that hold the cabinet in place. Be sure to not touch any of the electrical components inside to avoid shock. Visually follow the path the power cord takes as it enters the unit. The fuse ( usually clear glass with metal ends and cylindrical in shape ) should be located not far from where it enters the cabinet. Once located use a fuse puller or other means to carefully remove the fuse to check the element inside. If the fuse is blown take it to a hardware or electronics store for replacement. These fuses are cheap as this has happened to me before. Good luck!
Jun 19, 2011 | Whirlpool MH6110XE Microwave Oven
I have a microwave (Emerson Model#MW8111 SS and after removeing the cover to determine why I am not getting power I found a switch in line with the nuetral wire that is some sort of Klixon. It appears to...
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset-if the fuse is blown, it must be replaced. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the thermal fuse.)
Jan 12, 2018 | Emerson Microwave Ovens
Over the range microwaveoven worked flawlessly then bang it quit.it looks like its been unpluged but no. I tested the electrica outlet and ther is power. Is there a reset button within the microwave that...
you have a blown fuse.unplug the microwave. remove the vent by unscrewing the 2 screws holding it in place. gently pull vent grill forward to remove. open the door, and remove the screw holding the control panel in place. remove the metal plate being held in place by that screw. inside that panel is your blown fuse. remove the fuse and replace. reassemble the microwave. plug it back in.
Feb 08, 2011 | Panasonic Microwave Ovens
My spacemaker stopped working and no panel lights. It's not the circuit breaker. Any ideas? model JVM140001
Could be the fuse inside the microwave is blown. You will need to unplug the microwave and remove the front control panel. Inisde the microwave housing you will need to trace the electrical wire coming into the unit. Usually you will find the in-line fuse located on the black power wire. You can pull the connectors off the fuse and test it with a continuity tester. If the fuse is blown replace it but make sure you use the same amp rated fuse as you removed. If the fuse blows again then there is an electrical short somewhere in the microwave.
Dec 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker otr microwave - place of fuse - how
Remove the cover. Find the fuse probably on the floor of the machine. Of course, unplug it first.
Get a replacement at your hardware store
Nov 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM2070 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
