Question about Brother MFC 9700 All-In-One Laser Printer
Paper feed brother printer - Brother MFC 9700 All-In-One Laser Printer
SOURCE: Brother MFC-8440 shows "manual feed" and will not feed from tray
Press "Job Cancel".
Posted on Feb 04, 2009
SOURCE: WHEN PAPER FEEDS THROUGH PRINTER COMES OUT
Try these - is paper dry?
Are you using good quality (80 gsm minimum) paper?
Are the fuser rollers (open back of printer, pull down inner paper guide using projecting lugs) in good shape?
Is there any paper debris in the paper path either before the laser unit or on the final path (look carefully at the little paper separator fingers) that is impeding the paper run at one side?
Does the bypass tray give good or bad results? - if good, look for paper debris in the initial feed path.
Are any flexible plastic guides pulled out of shape to face back up the paper path - often caused by pulling a misfeed out backwards?
I find that paper scraps in the initial feed path can be impossible to see, so I have a piece of laminated paper to push through the feed path. It often finds bits I couldn't see.
Posted on Mar 05, 2009
  • 526 Answers
SOURCE: brother mfc-7420 printer - manual feed instead of automatic
ok, thank you
you probably had a document that was not using 8.5 x 11 paper or the print settings were the printer to use the manual tray.
thanks adi
Posted on Apr 20, 2009
komguy
  • 2306 Answers
SOURCE: my brother hl5250dn laser printer won't feed
Make sure the paper guide at the rear of the tray is not set too tight, it needs to be right on the mark for the size you are using. After that you can clean the rubber roller above where the paper sits with a towel damp with alcohol. If it still doesn't feed you may need a shop to check the roller drive gears and clutches.
Posted on Feb 05, 2010
SOURCE: Manual paper feed works but not automatic feed.
I've been told labels have to be manually fed on that printer.
Posted on Apr 01, 2010
My Brother MFC 210C Printer, Copier, Scanner isn't feeding the paper.How do I fix this?
Use a water dampened cloth to clean the pickup roller. They get residue on them over time that causes them to not grip the surface of the paper when feeding.
Feb 06, 2015 | Brother Office Equipment & Supplies
How do I use manual feed on the brother mfc 7820N printer/fax/copier?
The manual feed slot located in the front of the machine above the paper tray.
  1. Slide the gray paper guides to fit the size of the paper
  2. Using both hands put the paper (side to be printed, face up) in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the Brother machine feed the paper in a short distance.
  3. You must then go to the application that you want to print to the paper and use that application's paper settings to set the paper size, orientation, font, style, etc
  4. Good luck trying...
May 20, 2010 | Office Equipment & Supplies
Mar 30, 2010 | Brother HL 2140 Laser Printer
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Can the Brothers HL 2040 handle printing 65lb
It probably can but only from the front slot, the paper tray has to bend the paper around the roller in the front when feeding.
Aug 28, 2009 | Brother HL-2040 Laser Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother MFC 9700 All-In-One Laser Printer Logo
27 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
