Sony HVR-1500 HDV VCR Logo
Posted on Apr 24, 2010
Can't make vcr receive tv program - Sony HVR-1500 HDV VCR
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Jul 20, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
615
Points
Unit has no tuner so you must have audio and video input
  • Anonymous Jul 20, 2010
    not made for tv channels
How can i connect my 32" sony bravia?because the
Route the television audio directly through a stereo receiver. Connect the audio outputs of the television to the audio inputs of the receiver, using digital (coaxial or optical) or RCA (left and right audio) cables. Connect the left and right stereo speaker to the corresponding terminals on the receiver. Be sure that the positive and negative terminals of each speaker and the receiver are correctly lined up
Use a cable box. If your television doesn't have audio outputs, as many older TVs don't, use the outputs from a cable box to route your sound to the receiver. Proceed with a digital or RCA connection as described for the TV
Use a VCR. If you don't have a cable box, run the cable from the wall outlet into your VCR and then instead of outputting the audio to the TV, output it to the receiver so that you'll get sound from cable programming through the receiver and to the speakers, rather than to the TV. Connect the video output from the VCR directly to the TV for the easiest setup. You will then need to control your television programming with the VCR.
Change the program mode on the receiver to the input category you used to input the audio; for example, "TV," "Cable" or "Aux" are common options. You should now be able to hear audio from television programs on your speakers.
tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 • Televison & Video
tip
DISH Solo DVR VIP612 Limited Mode What is DISH Solo DVR VIP 612 Limited Mode?...
You can program your remote control in Limited Mode to keep from accidentally changing the channel on your TV or VCR and causing a snowy or blue screen.
  • When the remote control is in Limited Mode for TV mode, you will only be able to use POWER, MUTE, and VOLUME functions for your TV.
  • When the remote control is in Limited Mode for VCR mode, you will only be able to use POWER and the VCR functions for your VCR.
Note: Limited Mode is not used with amplifiers (AUX mode).
I hope that helps.
1helpful
2answers
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
tip
I hope that helps.
on Jul 05, 2010 • DISH Network ViP 612
tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
1helpful
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter
6.You are set
thanx
Connecting Hitachi VCR to my Direct TV.
Connect your Direct TV to the Ant. In connection on your VCR. When you want to watch TV, just tune the TV to channel 3 (or whatever channel the Receiver is set for). When you wish to record, set your VCR to that same channel and set your TV to the channel that your VCR outputs to. For simplicity sake, I would suggest setting both systems to channel 3 and just watching your program through the VCR. If you are still using an "off air" antenna, then connect that antenna to the ANT. IN connection on your Direct TV receiver and when you turn off the dish, it will pass the signal through just like the VCR would.
tip
I hope that helps.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
