Question about Microwave Ovens
Dacor Oven Mod# MRES30S 1 burner not working, could this be an element or control? How do you gain access to the element?
  • Jerry Kerns Apr 24, 2010
    Thank You, That was very helpful!
    President:
  • 949 Answers
The problem causing the element to not heat would be either in the control, the element, the sensor on the element or the element itself.
From my experience on this model the element is the most likely suspect. They use what is called a ribbon burner on this and they will typically fail before the control or wiring.
To check you would have to move the range out. Turn off the power, disconnect the screws holding the top on to access the element. Be careful with the glass top and the seal around the sides.
Once you access the element you can make an ohm check on the element terminals. Terminal to terminal should be under 100 ohms if over 100 then the element is bad. If this checks good you may need to do a power up test on the board, This is not recommended if you are not an expert as there will be live 240 volts.
Posted on Apr 24, 2010
How do I access the control panel so I can replace the fuse?
It depends on the type of oven. On countertop models, remove the outside cover. On over the range units, remove the control panel. You may have to remove the air deflector on the top first in order to gain access to the control panel screws.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 24, 2015 | Magic Chef MCD1611ST Microwave Oven
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
Microwave stops working. element is gone
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 =-
Aug 31, 2011 | Dacor Microwave Ovens
This an old range with side by side ovens which work perfectly. the 4 burners slide out, all 4 elements will heat, but do not get to a high heat, is there a control which affects all of the elements ...
Hi and welcome to FixYa, I am Kelly.
This sounds like your missing 1/2 of your input power. Go to the main CB panel and cycle the Range CB to OFF by pressing it hard to off and then back on. Test your burners again.
Still have the problem? Start looking in the area of the house to oven power connection / terminal block in the back of the oven for signs of HOT / burned terminals.
Still have the problem... Last check is to check wiring in the main controls area.
Without your model number this a VERY generic response but when all burners present the same symptom it is usually input power or control related.
If you respond with a model number I wil see what I can find that may help you troubleshoot your Oven.
Thank for choosing FixYa,
Kelly
Mar 23, 2011 | Microwave Ovens
Dacor micro/convection oven flickered then the power went out on it. Looked like it reset then I tried to micro something and it immediately shut down. :'( Its absolutely dead now. Is it a goner??. Its @...
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
If it's a problem with the controller / display, y
ou can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Aug 25, 2010 | Dacor DMT2420SS Microwave Oven
Dacor DMT2420S Blank display, oven does not work
It sounds like you need to have the control panel assembly repaired or your CPU unit replaced and you need a new bottom door switch.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Or you can order our exclusive modified control unit with our proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $30. It comes with a one-year guarantee. See details here.
We have the service manual and have uploaded it our site here to help you. It covers disassembly.
Also see this file.
You can order a universal type switch here for $5 postpaid.
Feel free to contact me directly for more help and information.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 02, 2010 | Dacor DMT2420SS Microwave Oven
Dacor Microwave DMT2420S control panel screen white
It is the CPU/display assembly that has a problem.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
In my professional opinion, there are weaknesses in both the design and manufacturing.
Our proprietary modifications and repairs are designed to not only repair these, but prevent them failing again.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you with disassembly.
Please tell your builder about us.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Jul 21, 2009 | Dacor DMT2420SS Microwave Oven
Dacor Touch Screen is flickering and doesn't respond to touch
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
Cleaning ge profile convection microwave
HI HERE THE STEPS TO DISASSEMBLEA gas range cabinet comes apart very easily. Here's how:
Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
PLEASE RATE IT.........................
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
