Question about Panasonic Viera TH-42PX80U Plasma TV
Cannot view full picture on screen
I noticed that the full picture does not show up on my screen, for instance the box score on sports events are only partially visible. I have adjusted the aspect ratio on the remote, but none of the views show the entire screen. Is there another adjustment I am missing?
SOURCE: Aspect Ratio not responding/always in "Full" mode
i have a panasonic th-42pwd8bk tv i have it working through my sky box, but it only works in black & white no colour. it works in colour on my pc what am i doing wrong. i have no user manual
Posted on Apr 22, 2007
elecgooroo
  • 57 Answers
SOURCE: heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Posted on Dec 10, 2007
SOURCE: Image has shifted to the left
Go to this thread - the instructions posted work.
You just need to buy the JIG to upgrade your firmware.
http://www.avsforum.com/avs-vb/showthread.php?t=534816&page=6
Posted on Feb 07, 2008
  • 45 Answers
SOURCE: Panasonic plasma
go in to your tv's menu and go in to picture settings , you either have the zoom function on or its been set on 4:3. check these and if zooms on turn it off or if 4:3 is on switch to 16:9
Posted on Mar 25, 2008
  • 31 Answers
SOURCE: Picture does not fit screen
make sure you cable set top box is set to proper aspect ratio should be 1080i
Posted on Mar 23, 2009
I have a Visio TV and I've noticed that I don't see the entire picture. On sports events, I can't see the scoreboard.
I would start by checking the Aspect ratio on your TV. You may have to navigate through your systems menu and locate settings to find this. (It should be located near the middle of your remote)
There would likely be a few options, one of which may be 'Auto'
-Additionally, try to using the Stretch or full-screen options.
There will be other options which are available to try.
Some helpful tips can be found here:
How to Get Vizio TV to Show the Full Screen Picture Techwalla com
Oct 26, 2016 | Vizio Televison & Video
I've notice while watching Baseball and Football games that it cuts of the the box scores on the top left hand corner and also on the bottom of the screen I'm not able to see all the content...
This problem u must play with the tv orignal remote.Look on the tv original remote for a buttons like Aspect Ratio,Picture Sizes,VIEW MODES,ZOOM.Just pushes one of these buttons until u have the desire screen format for u.The screen will jump every sizes,u can't get evrythings u want,have to give and take as the tv pictures exspan or contract.
Aug 12, 2011 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
Picture is too big for the screen i/e scores on sporting events cannot be read
Look for a "Zoom" or "Aspect" button on your remote. Press that untill the picture fits your screen properly.
Jan 07, 2011 | Vizio 42 in. LCD TV
Olevia 37" Hd flat screen, picture does not fit screen. Sporting event scores are off the screen.
You need to check the aspect or screen size settings on the TV as well as your signal scorce IE: cable box, satelitte if they are HD?
Sep 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Picture is too large. How do you change resolution?
On your television press the menu button to bring up the on screen display. Use the up or down arrows to find the aspect ratio control. Press the right arrow button to change the screen settings. Set the television to the best setting for your viewing pleasure. Hope this helps you with your problem. If you need technical assistance you can call Insignia customer service at this number: 1-877-467-4289. Hope this helps you with your problem.
Mar 29, 2009 | Insignia 37" LCD Flat-Panel HDTV
Cannot view the full picture
First, you have to tell me how the cable box is connected to the TV, by HDMI or component. If it is connected by HDMI, the cable box settings will override the picture size settings on the TV. It may be as simple as resetting the picture size on the cable box, but I am not familiar with the type of cable boxes that Comcast uses.
Apr 06, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Picture doesn't fit the screen
Try locating the aspect ratio adjustment on your cable box if you have one.
Mar 05, 2008 | Samsung TXL3276 32" TV
Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
smeags
Dec 30, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Image size too large, cannot see all of sports scores scrolling on the bottom
hey voiolentce. if you press the # button on the cablebox remote control you can fine tune the zoom by those 20 pixels you want. you are most likely set at zoom 1 currently. thats where i was when i had this same problem and it took me days to figure out that all i needed to do was press the damn # button. i couldnt see any of the scores on espn sports games and its been driving me crazy. hope this helps!
Sep 10, 2007 | RCA R52WM24 52" HDTV Projection Television
Panasonic Viera TH-42PX80U Plasma TV Logo
189 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
