Question about Toto Carlyle 1-piece Elongated Bowl Toilet
The toilet does'nt have the same flush pull taking a couple of flushes very slow draining
  • 299 Answers
Check the following: Is the water level in the tank properly set? Is the flapper valve opening fully when flushed? And is there any blockage in the waste line? Use a plunger to try and clear the line if the first two items are OK.
Posted on Apr 27, 2010
How do I fix a toilet that bubbles (small air bubbles from below) and flushes slow, and not completely very often?
Remove the toilet & have a plumbing company power snake
as much of the entire homes waste drain as possible
Maybe clogged inside the home on most runs & also out to
the street,have them do as much as they can, out to the street
Remove all toilets, so they can do good job & you can check &
clean them from under it
Have them run a camera down ALL drains & to the street
Jul 19, 2014 | Briggs Abingdon Ada Toilet Express
Tip
Tub drains slow
does your bathtub drain slow, and toilet not flush? dont call a plumber just yet, Every fixture in your home should have a air vent associated with it. the vents allow gases to escape and are necessary in allowing the waist water to flowout and down the pipes. most vents lead up through the roof, these are usualy 2" in diameter and raise up about 20" from the roof. there are other ventsin and around the home like the drain pipe for your washer or the overflow drains in sinks and tubs. If you have a tub that drains slow its usually hair buildup in the trap and is simple to clear. If you have a problem like the one i had and you've tried everything and it still wont drain the vent may be clogged. In my case the toilet wouldnt flush allong with the tub draining very slow, I threw every thing i could at the problem including removing the toilet and running a power snake. You can imagine how i felt when i put the toiket back in place and when i flushed it nothing happened:( after some thought i went to the tub and removed the chrome cap 0ver the overflow and ran a wire with the end bent like a hook as i pulled the wire out the toilet flushed, on the end of the wire was a clump of hair . problem solved!
on May 05, 2012 | Plumbing
When i flushed the toilet the water drained real slow and gurgled through the sink. also during the winter noticed a wet spot on the lawn where the septic tank is. would this be from the septic field
Yes, to your second question. As far as your first, this sounds like your air vent on your roof is clogged. You probably have something in the pipe. This has to be free to allow proper suction on the drain. This is important for air flow and draining. If that doesn't fix it, then there may be a clog in the line itself. Does it drain slow when you flush just water. It is possible you could have flushed something down the toilet that has caught on the trap within the toilet. I believe though the problem is in the air vent on the roof. Let me know back what you fin and we will go from there.
Mar 29, 2013 | Home
Toilet won't flush all the way. Drains real slow, sometimes flushes just fine. No drains are cloged. Water fills up just fine. You can hear it draining its just real slow. When we use the plunger it...
I wrote a tip that might apply to your situation:
http://www.fixya.com/support/r6633961-toilet_doesnt_flush_water_just_spins
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Eljer Toilet Onepiece Canterbury ...
Flush is weakening. Toilet paper won"t flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way...
put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
I have an american standard toilet which is flushing slowly. i have it off and drained and am trying to get a roto rooter to pass thru it. i cannot get this spring thru the toilet either from the bottom...
If you have that thing off, take it outside and put it up on saw horses, fill the back with water and flush it, see if it is still slow. Then get your kid to reach up there and get his toys out if it doesn't flush. You might have to do it a couple times. Then if it does flush, you know it is clogged down the line or something is blocking the vent. Got squirrels? Check it out.
May 20, 2010 | American Standard Traditional Champion4...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
I have a 3 bath rental. The last tenants were
With the toilet clean, try a large shop vac and see if that will unplug it , I had to do that when my son had flushed a toy and it was stuck. If that wont work you will have to pull the toilet.
Oct 24, 2009 | American Standard 2860.334 Enfield Two...
Toilet flushng
it sounds to me like depending on the flapper installed that your flush arm chain is too long and the flapper is not flipping back far enough to do its job. Take the lid off the tank and rotate the flapper up and back to see if it flushes correctly. if it does then your chain is too long and should be shortened. Hope this helps please rate me
Jan 10, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toto Carlyle 1-piece Elongated Bowl Toilet Logo
126 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
