Question about Magic Chef Refrigerators
MCBR1020W, 10cf., new fall 2009, defrost stops working
MCBR1020W, 10cf., new fall 2009, defrost only works 2 mos, then must be unplugged overnight to kick back in. Part was replaced once, told to unplug it periodically. Not satisfactory situation, might as well have an old manual defrost!
  • tcraryt May 16, 2010
    I have a Magic Chef Model 1020w 10 cu small standing refrigerator and the freezer seems to work ok but the refrigerator part is not keep food cold. The refrigerator part is also dripping water from the light area. What makes me a little angry is we just bought this at Home Depot less than 5 months ago. Tina
  • dottienic May 16, 2010
    Re: Magic Chef 1020W, 10 cf, new 8/2009. Followup is that the "complete defrost system" has just been replaced. This is in addition to the timer having been replaced in October '09. Don't yet know how long this will last, but I refuse to do the periodic unplug routine. Will continue to call for repair or replacement if needed. Symptoms listed by "tcraryt" in #2 are similar; eventually freezer won't work either.
    President:
  • 1,218 Answers
Good day,
You have an unlimited warranty for the first 12 months, and are entitled to a proper repair.
Could be a factory defect.
My advice is get hard nosed with them. The people you are dealing with did not design the machine but are responsible to correct or research or worst case scenario replace the machine.
The factory will eventually compensate them.
Posted on Apr 24, 2010
Testimonial: "Good answer. I'll try it, see if I make any headway. "
Windshield wipers stop working when the defroster is on
The only thing they have in common is the ignition switch.
Dec 18, 2015 | 2007 Chrysler Sebring Sedan
Side by side refrigerator model MCD2257HES, has stopped working. The fan isn't running, nothing is cooling. I unplugged overnight, plugged in this morning.
Is the defrost timer out of sync? Usually it defrosts early in the AM. If you unplugged it for a long time you will have to set the time on the defrost timer.
Aug 08, 2015 | Maytag Refrigerators
LG elecrocool refridgerator not cooling
it is mos tlikely frosting up on the evaporator, this shows up as frost on the back wall of the freezer that means its not self defrosting, check the defrost system, defrost termination therms can go bad, and need replacement, defrost elements can short out, defrost board if it has one may be bad.
Feb 21, 2012 | LG Refrigerators
My MCBR1020W 10 cu ft top mount freezer/refrigerator is not cooling correctly. It is -20 degrees in the top and 60 degrees in the bottom. This is a new item.
It is a cheap piece of junk. I bought one just this week and the defrost timer gets stuck so it's going back...........
May 14, 2010 | Magic Chef Refrigerators
Whirlpool stopped blowing cool air. Unplugged
It sounds as if your defrost timer has failed. Unplugging the unit over night allowed the unit to defrost. If unplugging it overnight or by using a stnd fan blowing into the freezer section for 90 minutes results in the fan blowing cold air then your unit is not defrosting. Most often the defrost timer is the problem. However there could be other defrost circuit like the thermostat or the defrost element. In order to provide you with the correct solution and defrost timer location you should privde your model number for further instructions.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Just stopped freezing....so i unplugged it...then plugged it back up and it ran for about a week....then done the same thing- quit working...so i unplugged it again....then plugged it up again and it...
Sounds like the defrost timer is not working. When you unplug it it will defrost and then as it runs it frosts up again till it stops the air flow and ....
Either buy a new defrost control and install it or have a new one installed by a tech.
Nov 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No air circulating the no frost refrigerator. Electrolux 2 door
It sounds like a defrost problem. Maybe the defrost timer is not advancing or it could be the heater in the freezer. Find the defrost timer and advance it to defrost. You will hear a click and the compressor should turn off. Then wait about a minute, unplug the cord slow. You should see a spark when you unplug. If you do then the heater is working. Change the defrost timer. If no spark then it could be the heater or terminator.
May 14, 2009 | Electrolux ER7526 / 1B Top Freezer...
GE Side by Side not defrosting
hello little G,
there are two more components that u need to check,
the defrost heater. ( heating element ) - it should have continuity ( low resistance )
and the bi-metal. ( should have continuity while the coil is covered with ice.) check it before you unplug the fridge.
the main board that you replaced is just the controller for defrosting.
tnx 4 using fixya,
drcool
Sep 16, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
MY FREEZER WORKS BUT THE REFRIDGERATOR IS INOP
ER DH is a defrost problem. You need a controller assembly which is a thermal fuse. It is located in the freezer compartment. If you unplug your unit and wait a few minutes it will reset and run for 5-7 hours until it hits the defrost cycle again. You need to get service.
Sgt 48
Dec 25, 2007 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
801 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
