Question about Epson WorkForce 600 All-In-One InkJet Printer
When I do a nozzel check the black ink on my Epson Workforce 600 does not print. How do I clean the printer head myself?
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Epson workforce 325 printing blank with black ink
The print head is plugged up. Try the nozzle check function or the clean function on the control panel.
Oct 07, 2016 | Epson WorkForce 325 Inkjet Multifunction...
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
Epson workforce 600 Horizontal White Lines
Your print heads may be clean, but it sounds like there is either a gouge in the heads one of the other components that touches the paper (transfer roller, imaging drum, whatever is on this model).
Dec 11, 2012 | Epson WorkForce 600 All-In-One InkJet...
My Epson Workforce 600 printer will not print black ink. I have changed ink cartridges several times and have cleaned the heads/nozzles several times. What can I do to fix this?
It appears that your printer is malfunctioning and will require service. Contact Epson and verify if your printer is still under warranty so they can replace it. Otherwise, have your printer check by the nearest service center in your area.
Oct 23, 2011 | Epson WorkForce 600 All-In-One InkJet...
I have an almost full black ink and my color ink is running a little low.. but when I did a test page.. color prints, but the black does not.. I did a couple cleanings.. like 4 times.. and totally wasted...
because you don't use it enough the nozzel is probably blocked with dried ink, even the cleaning option wont work in this case, the only thing you can do is to get help from a professionnal technician to unblock the nozel, some times diping the printing head in hot water unglogges it and some times the technician needs to force a cleaning/ink solution through the nozel with a surringe, but what ever you do (DO NOT USE ALCOHOL) you will damage the print head.
Aug 18, 2011 | Epson WorkForce 600 All-In-One InkJet...
Epson workforce 600 prints with no black. Have installed new cartridges, cleaned heads numerous times, uninstalled/downloaded driver/reinstalled -- still no black printing.
new ink carts, cleaned heads, reloaded drivers ?
hardware issue, you already performed troubleshooting needed for this issue (try calling tech support and same steps will be provided)
better check your warranty or ask for repair options
Apr 07, 2010 | Office Equipment & Supplies
I have an Epson Workforce 600 printer that won't print black ink. I have replace all the cartriges with new and still no black ink. I've done nozzle clean several times. Only a very faint line on test...
You may have to clean your HEADS. I found this on the Web. Hopefully this will help. Pls rate me.
Good Luck
Found this on the Web:
http://www.fixyourownprinter.com/forums/inkjet/14116
Epson Stylus Head Cleaning Solution Plus
Re: Epson printer problem
You will want to press the button that you use to change the ink cartridge (the 3rd button). Once the carriage is in the "cartridge change position" you can unplug the printer. Then you are ready to flush out the heads. Click here for cleaning instructions http://www.wesesweb.web1000.com/printhead.html
The instructions are fairly easy to follow. If you need the head cleaning solution click here .http://www.fixyourownprinter.com/kea0.html
Repairs: All Epson Stylus printers (except for the C64-C86, CX4600-CX6400 series) which don't print, or print choppy in black or color. For the other printers, as well as Canon BJCs, use the other repair kit.
Description:
  • This is the same chemical used by Epson in their service department
  • Easy to use, no disassembly required
  • Gently dissolves even the most stubborn clogs and restores output to dried out print nozzles and clogged printheads
  • In our testing on an Epson 600 that sat unused for several months, it 100% restored a head that had no output, with one application (Individual results may vary)
Note: This is not alcohol or Windex; it is an ink-specific solvent that has proven to be safe and effective for use on Epson printheads. Do not use alcohol or Windex, they will very likely ruin your printer.
Kit Includes:
  • 1 oz bottle Epson Stylus Head Cleaning Solution (enough to fix several printers)
  • 1 syringe applicator for dispensing solution
  • Simple directions for use
Price: $9.99 order form on link below
http://www.fixyourownprinter.com/kits/Epson/K89
Feb 25, 2010 | Epson WorkForce 600 All-In-One InkJet...
I had the same problem. I didn't believe it would work since I "cleaned the printer heads" once and nothing happend. But I read in the Epson manual it can take up to 4 times. I had to do it 3 times and now it prints good as new!
Jan 10, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Epson WorkForce 600 All-In-One InkJet Printer Logo
1,586 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
