Question about Estate TEDS740JQ Electric Dryer
My dryer will not come on period and The
My dryer will not come on period and The connection is good. where do I find the thermal fuse in the Estate TEDX640JQ Electric Dryer?
    President:
  • 949 Answers
The thermal fuse is located behind the back panel just to the left of the exhaust opening (looking from the back), it is white in color and has 2 wires (usually blue) going to it.
If you dryer comes on sometimes I would suspect this is not the problem.
The symptoms you describe most often are a loose wire or a bad motor.
Posted on Apr 24, 2010
TEDS840JQ no heat
It probably has a bad timer. To check the timer set your meter for ohms or tone if you have tone. Connect a test lead to the terminal that connects to the large red wire from the heater. Now check for continuity between that point and all other terminals on the timer. if ya cannot get a reading the timer is bad. Here is my video:
Estate Dryer No Heat
Dec 02, 2013 | Estate TEDS840JQ Electric Dryer
The thermal fuse keeps blowing
If you pull it out of closet and replace fuse and it works even after turning off again etc for several times--something is happening when it gets put back---did you disconnect venting connection when you pulled it out?
Dec 17, 2012 | Estate EED4400WQ Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
The dryer is not heating up.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpgCheck the thermal fuses and replace the one that has no continuity.
Jan 20, 2011 | Kenmore Dryers
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
The dryer runs but there is no heat coming out of it
lllThis is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
Jan 18, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Replaced the coil and still not heating up on my estate dryer
The thermal fuse (aka thermal limit switch) is probably blown. It is not a good idea to bypass this fuse -- if the dryer overheats, it will not cut off the heating element -- fire is likely in that scenario. If you want to troubleshoot the problem, let me know,
Charlie
Sep 26, 2009 | Estate TEDX640JQ Electric Dryer
Estate dryer won't come on..
check the white thermal fuse on the blower housing
Apr 26, 2008 | Estate EED4300SQ Dryer
Estate TEDS740JQ Electric Dryer Logo
334 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
