Question about Samsung ML-2150 Laser Printer
My samsung ml 2150 prints dirty pages with black smudges. I have vacuumed it and run cleaning sheets, I am using cheap re manufactured cartridge. How can you tell volume usage? Maybe it needs other consumables
5 Suggested Answers
Nicolomd
  • 84 Answers
SOURCE: Samsung ML-2510 print problem
it is a new one cartridge or not? was it refilled?
Posted on Jan 04, 2008
Tech Jenkins
  • 359 Answers
SOURCE: dirty printing
The cause of this is a faulty toner cartridge. What happened was some toner spilled out of the cartridge and down into your printer. Take the toner cartridge out and with a damp paper towel just goto town and wipe everything down.
Replace the toner cartridge, and in about 20 pages it should clear up.
Posted on Aug 18, 2008
SOURCE: Paper Jam when using duplex function - Samsung ML-2551N
Check underneath printer.
Posted on Nov 10, 2009
  • 11 Answers
SOURCE: my samsung clp-315w prints smudgy black lines
Cleaning my unit resulted in the solution of this problem. I removed the toner cartridges, the imaging unit, and the waste bin, opened the back door as well, and blew it out with "canned air". This will not solve all problems, but it is the right place to start. be careful to keep the imaging unit out of bright light when you you have it out of the printer.
Posted on Mar 21, 2010
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
I have an Samsung ML-2851ND printer and it is printing grey patches vertically down the pages behind the text. What is causing this and how can it be resolved?
Dots, Lines and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Open the front cover and take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots.
Try to rotate the drum to clean its whole face. You may have to repeat cleaning more than once.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Dont forget to appreciate the solution and to convey your feedback
CreativeTECH
Jan 24, 2011 | Samsung ML-2851ND Laser Printer
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
When printing on ML4550B, there is a ~1cm intermittent black patches vertically on the right side of the printed page.
This is possibly toner on the paper feed rollers. If you happend to use refurbished cartridges they are often over filled to claim more pages for your buck. But they fail to say expect smudges down the printed page.
use a cloth and some metho to clean the paper path
Please rate my help++++Thanks for using FIXYA
May 18, 2010 | Samsung ML 4551NDR - printer - B/W - laser
Price of cartridge of samsung ML-1640 mono laser printer
Rs. 2800/- original carteige
Rs. 1200/- compitable cartridge
Nov 09, 2009 | Samsung Laser Multifunction Printer Toner...
Black streaks on paper ML 2150 laser printer
Black streaks usually mean that toner is baked on. Pull out the old cartridge, if it has a lot of toner, vacuumn it out (unplugged of course), and then replace it with a new cartridge.
Apr 28, 2009 | Samsung ML-2150 Laser Printer
Samsung ML-2010 Mono Laser Printer leaves unwanted marks on page.
if older printer or well used printer (All laser printers if they have print quality issues - it is mostly either the toner or the fuser). the only way to tell is get (borrow) a toner and see if problem is the same or remove the fuser (the hot thing in the printer) and see if the "ironing" unit or fuser rollers are dirty or worn out or scratched
Mar 01, 2009 | Office Equipment & Supplies
Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Jan 03, 2009 | HP LaserJet 1600 Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Samsung ML-2150 Laser Printer Logo
103 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
