Question about GE Profile WPRE6100G Top Load Washer
Water comes out verryy slowly when using cold wash GE large capcity washer
    President:
  • 2,468 Answers
Check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Posted on Apr 24, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Replacement of cold water valve on ge model wpgt9360eoww washer
Is this a new development or has it always done it slowly? Before jumping to parts changing, make sure it isn't something simple like a kinked or obstructed hose or even something like someone nearly closed the supply valve!
Dec 02, 2014 | GE Washing Machines
Frigidaire Affinity ultra capcity front load washer is not sencing the load it spins but the light stays lit on load sencing and will not fill with water! I have tried getting an error code with no luck!...
If your problem is No water coming IN the machine, then it is One of your two water inlet valves need replacing. Feel the water that IS NOT coming in. That will tell you which valve. Cold only water means the Hot water valve is bad. If the water is NOT leaving the machine it will not spin and you need a New drain Pump installed.
Feb 10, 2014 | Washing Machines
Water for intial fill works fine . when it goes to rinse cycle the water just dribbles in making wash time go on for ever ! whats the solution?
when you start the washer set it just on cold and see if it fills slowly,when the washer goes to rinse it just uses cold water,you could have a problem with the washer or in the house,when you run it on just cold and if it dribbles in,stop it shut down the water going to the washer,remove the cold water hose from the back of the washer,stick it in the sink or inside the washer and turn it on,if it comes out strong then you have a bad water valve on the washer,if it comes out slowly you have a bad water valve in the house and it's not the washer.hope this helps
Sep 12, 2011 | Washing Machines
My washer will only use the hot water
  1. First, make sure that your cold water valve, behind the washing machine, is turned on, and water is coming out.
  2. If there is water coming from the cold water valve, this water goes to another valve inside of the washing machine. Open your washing machine and take out the Diagnosis Manual (usually found in the top portion of the machine with the computer boards, or on the back panel)
  3. Diagnose the Water Inlet Valves per the instructions in the Manual.
Jul 15, 2010 | GE WSXH208A Front Load Washer
The water is coming in very slowly. This started
There are screens inside the water inlet valves. Remove the water hoses and you will see them.
Jan 17, 2010 | GE Washing Machines
Can I use only cold water with my GE front load washer
Just used the cold water and plugged the hit water tube. It worked.
Mar 18, 2009 | GE Profile WPXH214F
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Ge profile whsb8000bocc
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
May 12, 2008 | GE Profile WPSR3120WWW
GE Profile WPRE6100G Top Load Washer Logo
142 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
