Question about Compaq Creative Sound Blaster PCI 128 Sound Card
No voice detect in microphone & speaker
I just switched my OS from Vista to Windows 7...but when using voice call in yahoo messenger...there is no voice detect in microphone & speaker...but i can still listen to the music in my laptop...HELP ME PLEASE!!!
    Genius:
  • 1,189 Answers
  • Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the Audio Drivers. Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel. Scroll to find, "Hardware and Sound, select "Audio Devices and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" the (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced), “not recommended!” In the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: “Click the "OK" to all change; 'Save,' and apply!” before exiting. “Rating the solution is appreciated, thanks”
Posted on Apr 24, 2010
Jackpot00 my yahoo messenger voice doest not work
Run the Call Setup Assistant. This tool is built right into Yahoo! Messenger.
To run the Call Setup Assistant:
Click the Messenger menu.Select Preferences.In the Preferences dialog box, click Calling & Devices.In the Calling & Devices dialog box, under the "Test Audio" heading, click Open the call setup assistant.Click Next to go to the "Microphone Setup" page.Choose the microphone you want to use from the pull-down menu, then speak into that microphone.Click Next to go to the "Speakers Setup" page.Choose the speakers you want to use from the drop-down menu, then adjust the volume with the slider on the page.Click Finish.In the Preferences dialog box, click Apply and then click OK.
NOTE: Colored lights on the page indicate your microphone or speakers are working.
Nov 03, 2011 | Dell Inspiron 530 Desktop Computer...
No sound in yahoo messenger
Here's how to troubleshoot microphone and speaker problems:
1. Click the Messenger menu and select Preferences. The Yahoo! Preferences window will open.
2. Under Category on the left, click Voice & Calls. in version 9 or Video & Voice in version 10.
3. Check the microphone and speaker settings:
- For Yahoo! Messenger 9.0, test your selected speaker by clicking the little Play arrow beside it. Then test your selected microphone by speaking into it, if it's working you'll see an animated level indicator.
- For Yahoo! Messenger 10, test your microphone and speakers by clicking the Open Video and Voice Setup link.
4. Check your system volume by clicking the Speaker icon in the Notification Area of your Windows Taskbar, located at the bottom-right corner of your screen.
- Drag the Volume bar to the top.
Remember: If the little speaker icon below that volume slider has a red circle with a slash through it (no symbol), your sound is muted. Click that speaker once to turn off muting.
- Next, if that didn't work, go to the Mixer, located below the volume bar or access it by double-clicking the Speaker icon in the Taskbar. Make sure that none of the options has been set to mute, and that all levels are set to above 50%.
Your microphone and speakers should now be functioning properly.
Here are some additional things to consider:
- If you're using a headset, make sure that the jacks are plugged in to the correct connectors on your computer and that you haven't accidentally selected a mute switch.
- If you're using a USB headset, make sure your USB connection is functioning properly. Try using another USB device in that connection to test to see if it works.
For more help regarding yahoo messenger, visit
http://help.yahoo.com/kb/index?page=product&y=PROD_MSNG_MSNG10
Sep 05, 2010 | Yahoo Messenger
Yahoo voice call not working
Make sure ur mic settings are configured properly.
Open Yahoo Messenger Window, goto Actions > Call Setup as seen below:
Now follow the step by step instructions, and select the input and output source from the drop down menu on the setup screen until the microphone and speakers are working properly with this wizard.
Yahoo Audio Prefernces
Go to yahoo messenger main window , Messenger > Preferences > Calling & Audio
In this setup, select the microphone input from the dropdown, and similarly the speaker settings.
After selecting the proper input and output, the voice char worked just fine with me. Hope it helps you solve your problem.
Aug 26, 2010 | Yahoo Messenger
My yahoo messenger voice call pc-pc working but the other side can never hear me! But if I use skype no problem. It used to work but may be because I changed my wireless router to Belkin! But I also turned...
Try running through your settings again
Typical audio set up
Laptop with mic x webcam with mic x Vista x Yahoo Messenger 10
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Video and Voice
Set webcam mic and speakers to show Default equipment
Open Video and Voice Setup to test audio equipment
Click 'Place a free test call'
Check box 'Allow USB devices to access Messenger'
Click 'Apply' click 'OK'
May 15, 2010 | Yahoo Messenger
Why cant i get voice in yahoo messenger.i know
Not all Yahoo Messenger International versions support this feature.
You have version 10.0.0.1102-in
Jan 06, 2010 | Microsoft Windows Vista Ultimate Edition
Cannot make a full connection to yahoo messanger it shuts down.
First please uninstall the yahoo and install the latest version of yahoo messenger from net. Next please follow the step by step troubleshooting if you are still facing the issue:
Instructions Step 1:Reduce echoes by using a headset instead of speakers and a microphone. Place the microphone farther away from the speakers, if possible. Adjust the volume of the speakers and the microphone.
Step 2:Verify your Internet connection speed if your friend's voice sounds choppy. The computer modem speed must be 56K or higher in order to send voices or sounds.
Step 3:Go to "Actions" and "Call Setup" in Yahoo! Messenger if you can't hear, or your friend can't hear you. Test the sound by following the instructions that proceed call setup.
Step 4:Click on the speaker icon in the lower right corner of your computer screen if you want to test the sound manually. Uncheck "Mute," if necessary, and make sure sound levels are above 50 percent.
Step 5:Pick "Preferences" in Yahoo! Messenger if you have trouble with connecting to the voice server. Choose "Connection," then select "No Proxies." Log in to Messenger again to check the voice server.
Tips & Warnings Follow your computer system's instructions for checking or modifying the server's TCP ports. Ports numbered 5050, 443 or 80 must be open for the voice features to work.
Install the audio codec software that comes with Windows. PC calls and voice chat require that the software is enabled on your computer.
Thanks for contacting Fixya.
Jun 22, 2009 | Microsoft Windows XP Professional
Yahoo Messenger 9.0 Voice Chat Drops
Normal 0 Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Jun 10, 2009 | Yahoo Messenger
Yahoo Messenger 9.0 PC to Phone call results in No Voice Detected
Not a permanent solution. Rebooted the computer and I was able to connect. Tried calling again later and same problem occurred (No voice detected). Re-booted again and it cleared up. Haven't tried calling again yet. Never had this problem with messenger 8.
Mar 19, 2009 | Yahoo Messenger
Yahoo messsenger voice chat problem
yahoo search engine brings up something different than what I put into search
Jan 13, 2009 | Yahoo Messenger
Microphone not working Need help please
Make sure it's plugged into the Pink Jack on the computer. You probably already know that, but if not hope this helps. Bud
Jul 19, 2008 | Computers & Internet
Compaq Creative Sound Blaster PCI 128 Sound Card Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
