Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon d80 verious full batteries flashing empty. HELP!!
Help!! My D80 when used with a full battery is showing the battery is full then after a shot is flashing empty. I have tried this with four batteries, two one year old and two brand new. It gets worse, my original body is only a year old when this problem started. I am travelling at the moment and only had two days in london to fix the problem but nobody could help me. In my desperation at the thought of travelling for another four months with out a camera I bought another body only to discover this problem happening all over again. I'm at my wits end. Please help!!
  • 2 more comments
  • Anonymous May 06, 2008
    Same damn problem.
  • lisafurie Aug 21, 2008
    I am having the same problem! I sent my camera back, and they returned it saying they cleaned it up and that it was now fine. Still not working! Don't know where to go now.
  • Anonymous Nov 20, 2008
    I have the same thing and my local camera store's only solution is to send the camera back to Nikon - with a 4-6 weeks turn around time! No thanks!
  • James Korolas Dec 05, 2008
    Seems to be a design flaw with this camera.
    This is the third one I had where this problem occured. It's worse with the VR lens mounted, leaving me to believe that Nikon must be aware of this but has no way of fixing it, hoping/knowing that the problem does not occur often enough to be an issue that would impact sales. But then, I think the camera is discontinued now...
  • 3 Answers
I just went to Nikon USA's website and they now have a firmware fix for this issue!
It states:
Modifications enabled with upgrade of A and B firmware to 1.11
  • An issue that, in some rare circumstances, caused the battery indicator to blink, regardless of actual battery charge, has been resolved.
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=16091&p_sid=PdGuUCkj&p_lva=13783&p_accessibility=0&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9OTIsOTImcF9wcm9kcz0xOSwzMDkmcF9jYXRzPTAmcF9wdj0yLjMwOSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x&p_li=
Posted on Dec 05, 2008
  • 78 Answers
I dealt with the same issue a couple years ago - replace your charger. It didn't make sense to me either until I realized that the only thing 8 batteries and 2 cameras had in common was one charger.
That should do the trick. Let me know if there's anything more I can do for you, and please don't forget to rate fixya.
Posted on Apr 08, 2008
The battery flashing just started for me too. To "fix" it, I took the battery back out, turned the camera on and off a few times (with the battery out), put the battery back in and it worked.
Posted on Dec 20, 2008
I have the sampe problem but I noticed that this is an issue only with the AF-S Lenses and does not happen with the screw drive focus lenses
Posted on Jul 13, 2008
This is a wide-spread problem and the most plausible cause proposed is bad connection between the body and the lens. Try to carefully clean the electrical lens contacts on both the lense and the body.
Posted on Jun 14, 2008
Nikon D80 w/ 18-200m VR
Don't replace the charger! I have the same issue using two batteries and two differnent chargers. Contact Nikon customer support. The false low battery issue is an issue that several others are experiencing.
Posted on Apr 21, 2008
Nikon D80 showing empty battery
Are you using the same charger for all of the batteries? If so, you might want to try another charger. I had a charger for my batteries (I have a D7000) that turned out to be bad. It would show it charging and then having charged them, but they were still dead.
If that's not the case, check the contacts inside the camera, that they are clean and free of debris. Those little gold contacts needs to match up nice and solidly.
If it's still a no-go, call 1-800-NIKON US (1-800-645-6687) 9AM-8PM EST, Monday through Friday.
Mar 16, 2014 | Nikon D Cameras
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Jan 09, 2013 | Nikon D80 Body Only Digital Camera
Nikon d80 dslr camera working fine and then one day turned it on to take pictures only to find an err message flashing and when the shutter button depressed it says r04. The shutter sounds but no pictures...
HiI am sorry to hear, but you will have to some professional. Regarding your d80 has common problem of sequence unit defective. I believe that is the problem and your local repair shop would charge around $75 to 235 depend on what they really want to charge. Thanks and best regard!
May 27, 2011 | Nikon D80 Digital Camera
D80 "battery drained' and "F"sign when pressing release button
Pls make sure of the following:
- You are using original Nikon batteries (generic batteries gave a similar problem to me)
- The aperture ring of your camera is correctly placed
Nov 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
My Nikon D80 flashes "off" or error and won't take a picture
Is the battery charged?
Do you have a memory card in the camera?
Is the card empty?
Is the lock on the memory card off?
Jul 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have a problem with the d80 Nikon, sometimes the batteries fail it show me empty, but when i turn it off and then turn it on it show me the batteries is full.
Your camera has a built in diagnostic computer. When Nikon gets the camera it connects the camera to a computer to checks for faults much like modern day cars. There is nothing you can do other than try another battery or send into Nikon. Batteries like camera can be bad.
Jul 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
Low Battery Indcator Flashes
You can check the status of your battery, including chargeble life remaining, in the Setup Menu. You need to have the CSM/Setup menu option to display Full menus, not Simple, in order to get battery status. So see if that battery status selection says you need to replace the battery.
Since you can shake the camera to get full battery, it's possible the battery contacts (on the battery or in the camera) are dirty, so check that.
If you do need a new battery, spend the few extra bucks to get a genuine Nikon EN-EL3e from a Nikon dealer. I have learned that many off-brand batteries do not properly implement a needed reserve, and "Genuine Nikon" batteries bought online from non-dealers are often counterfeit, just relabeled junk.
Mar 01, 2009 | Nikon D80 Digital Camera with 18-200mm...
Nikon D80 Exposure Count
My camera is now fixed. It was a tiny speck of dirt on the sensors between the mounting of the lense & the camera. The uy that fixed it said it is a problem with the camera because they are so sensitive.
Jan 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
539 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
