Question about LG Flatron 915FT 19" CRT Monitor
LG Flatron 915FT Plus - vGA - Run at 1024x768
My screen keeps having 'fuzzy lines' through it. This happens from time to time. I thought it might be a power issue (not enough) so I am now running PC & Monitor off separate points. I have also used the drivers I got with the monitor (i.e. ran the 915FTPLU.inf files through windows XP).
What I find is that the sceen distorts in certain areas - i.e. certain parts of text or images. This sometimes gets quite bad & happens on large parts of the screen.
The monitor is being powered by a 512Mb/AGP 8x card at 1024x768
It also has an independent power input
Any suggestios as to why this might be?
Is there a diagnostics tool that I can get for it?
Many thanks for your time & help
Cave
sandrew
  • 2961 Answers
SOURCE: Cant get 1280x1024 when connected to laptop
the only way you may get it to work is if you use the monitor a secondary device and also use the notebook monitor as well. But the problem may also be the vga connector converting the signal, as you may have to have a DVI connection on your monitor to obtain widescreen resolutions.
Posted on May 28, 2007
SOURCE: LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Posted on Jul 27, 2007
jmgldsmth
  • 1906 Answers
SOURCE: lg flatron w1952tq monitor goes immediatly into power saving mode
reinstall windows
Posted on Sep 06, 2009
SOURCE: LG screen goes in stand by.
oke having a similar problem atm, this is what i have found so far. was trying to help a friend who has bought the same 19" LG monitor. When i connected the monitor to her PC i noticed that it was not the same connection as the previous one but it had the smaller blue connection..this shouldnt be a problem but it was. The monitor when powered up, showed LG logo then went into power saving mode. My next step was to try the monitor on my own PC to make sure it was working, When i did this the monitor got a signal but on the initial boot it did say that this monitor was not compatible currently the way i had it set up ( where i had it plugged in? the only place it can be) because of my graphics card. oke so atleast i knew the monitor was working and was recieving a signal.
the only difference i can see is when i put it in her PC it is not giving me this information which also did give 3 steps to solving the problem but didnt seem legit. the next step i will take is to try my monitor on her PC although im not sure i expect it to work.
i think it must be a) PC is now faulty or b) PC is not sending a signal to the monitor ( possibly due to the fact it is not the same connection as before.)
what i have seen on other similar posts says you should also listen for your PC starting up normally.
another thing i would like to know i think it can be usefull for this topic. are the people who are experiencing this problem in the same situation as me i.e. changing the type of connection used by the monitor from the larger to the smaller type?
id also liek to note that the monitor i have was bought on a tight budget from PC world.
only other help i can give to people with this problem is that it is much easier to see where the fault is when you have 2 PC's and 2 monitors i know this is not viable for many but if atall possible interchanging parts with the PC that is working correctly and the one black screening can help you see exactly what the problem is,
as far as i know aswell the main reason for a monitor to sleep is that its simply not getting a signal from the PC BUT on rare occasions it can be a fault in the monitor. IF you have another monitor with the same connection that you can get yto work on the same PC its the monitor with the problem, if u have a monitor that u know is working on another PC with the same connection but is not working on the PC in questions its a PC fault.
sorry for the jumble of words in this answer i tryed my best to explain, all my knowledge of PCs is from friends and self tought so ... hope it helped
Posted on Apr 07, 2010
budmrtn
  • 11361 Answers
SOURCE: Hello, I have a LG Flatron W1934S screen. When I
Try it with another PC first just to be sure it is not video card problem.
More likely that it has dying power supply due to bad caps with leaking/bulging tops a shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/LG%20W1934S/
You should replace them in a set.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 30, 2010
Horizontal line, audio ok in LG flatron 21'' TV
It sounds like you have lost the vertical sweep circuits, it can be the Vertical out put IC is bad, Vertical yoke winding is bad, caps is bad. You will have to open it up, but you must be real careful since the picture tube can hold high voltage (24~30,000 Volts) for a long time after the monitor is unplugged, you will need to discharge the picture tube first before working on it. You may want to leave this to the pro.
http://s807.photobucket.com/home/budm/allalbums
Apr 30, 2010 | LG Flatron 915FT 19" CRT Monitor
How to remove ink of a gel pen from a LG flatron monitor
Try Goo Gone. Its a product I use to get rid of marker lines, pen lines, You can find it at Office Depot or places like that, it comes in a plastic bottle and looks like this:
http://www.amazon.com/MAGIC-AMERICA-GG12-Goo-Gone/dp/B00006IBNJ
Works very well.
Ben
May 23, 2009 | LG Flatron 915FT 19" CRT Monitor
My monitor goes blank sometimes
it is possible depending on the age of the screen.
also check your cables and keep them clean.
Jan 19, 2009 | LG Flatron 915FT 19" CRT Monitor
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
LG FLATRON 915FT plus monitor OSD setting
1. clean the G4 wire.
2. change the neck base.
3. adjust the focus preset in LOT .
Oct 16, 2008 | LG Computers & Internet
Display zooms and blanks
Sounds like it has a CRT and the EHT is collapsing. Maybe a dry joint around the timebase output transformer.
Mar 18, 2017 | LG Flatron Computers & Internet
May 28, 2007 | LG Flatron L1710B 17" LCD Monitor
Image width instability
on the pc, choose a 640x480 vga screen...if ok, then gradually build higher res screens from there
May 27, 2007 | LG Flatron 915FT Plus (White) 19" CRT...
LG Flatron 915FT 19" CRT Monitor Logo
67 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
