Question about Whirlpool Calypso GVW9959K Top Load Washer
I am getting a stuck relay error and the washing machine won't operate.
Hendset lock
Posted on Apr 24, 2010
F-08 indicated.
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
Jan 29, 2016 | Hotpoint Washing Machines
Start machine and let's water in for few seconds then makes screeching noise and stops code F08 on display any ideas to what may be problem
Some descriptions on various models also still say "heater relay", or "heater relay can't be activated", or "heater relay stuck", but also add, "check pressure switch connections for heater, wiring and module connections".
May 06, 2015 | CDA Washing Machines
Hi I have a Hotpoint WD860 washing machine, when trying to start to select a program, the machine won't start, it just counts down rather than starting the whole program itseslf. When I tried to end t
First all all unplug it for 2 mins to clear error code. That error relates to heater or pcb fault. Check the wires on the heater then pcb make sure they are tight. Give the relays a tap on the pcb it could be stuck. Pcb is module / circuit board etc. Found at the back in the corner with a White cover over it. Remove rear cover to see. Relays are on the pcb.
Sep 01, 2014 | Washing Machines
Why is the Washing machine door does not open?
The door latch is normally locked by a relay whilst the washing machine is operating to avoid accidental door opening and flooding. Once the wash is complete a timer operates and releases the door latch relay to allow door opening. The relay must have stuck. Try to turn off the mains power supply to washer and if you hear a click then relay has released and the door should open. But if no difference then the relay or latch is jammed and you will have to use a mild force with a blunt screw driver to force open the door. If this is hard then take the washing machine cover top cover out and access the switch from side. Make sure the mains power cable is taken out.
Aug 02, 2014 | Washing Machines
What is F08 error means in Ariston washing Machine
You did not specify model!
F08 - Heater relay cannot be activated
  • Check wiring
  • Check pressure switch and connections
  • Tap relays as they can jam on new boards
  • Check electronic control PCB
  • Check heating element
Dado
Jun 21, 2014 | Ariston Technologies Washing Machines
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
F-05 MESSAGE HAS COME UP ON MACHINE WHAT DOES THIS MEAN?
hi have a look below hope this helps, then goggle how to fix it!
Sep 06, 2011 | Hotpoint Aquarius WD640 Front Load...
It flashes f o7 on my wie 127
hi sir, It seems that a common error code on Indesit washing machines is error code 7. This code can show itself as F 007 or with washing machines that have a rotating control dial the door lock light can flash in cycles of seven times.
This error code usually means, “heater relay stuck”.
The heater is switched on via a relay built into the main PCB. This relay is known to get jammed causing error code 7. In my experience this has usually meant a new PCB needed fitting and as the PCB comes without the main processor EEPROM chip one of those is needed also.
This repair is going to be expensive. I have heard anecdotally of engineers freeing off the jammed relay by giving it a firm tap. However, I would not expect such a repair to last as the chances are the relay would just get stuck again later on.
If a washing machine is still under the five-year parts warranty it would be cheaper to let the manufacture fit these parts but although the parts would be free the labour is going to be about £90.
kindly rate me..
thanks for using fixya..
Feb 12, 2010 | Indesit Washing Machines
Hi our washing machine keeps displaying error code f12 and will not go on does anyone no what this means carolyn
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Nov 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
