Question about Megxon X33 Digital Camera
How do I get my computers to transfer files
I have a fully connected network with internet. two wireless conected to a hub and the main one. thing is I can't transfer files from one comp to another?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 59 Answers
Enable file sharing
Posted on Apr 25, 2010
Motorola SBG900 LAN problems
This is simply a firmware problem of your Motorola Router so what is the best thing to do here is to update the firmware of your router, you can download the latest firmware from Motorola's web site....
Oct 21, 2008 | Computers & Internet
Computer does not connect
NEW LAPTOP? Noticed a lot of post for same Laptop as same time.
If try to use wireless - you need to set-up wireless part of router and wireless part of laptop (Wireless Software).
Setup your network same it is on the PC.
Use Network setup wizard, if not know how in system manager, in the control panel.
Network Name is same on both, MYHOUSE is good.
The only thing different should be NAME, like SYS02,
PC would be SYS01, and IPaddress ( first 3 sections same as PC - Last section is indivual system - example follows:
PC = 192.168.1.40 then LT = 192.168.1.41
Suggest you hard wire laptop to router to verify network connection then work on wireless connection setup after you get connected thru hard line.
Mar 17, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
How do I do file transfers from one wireless laptop on a westell 6100 dsl model to another wireless laptop on the same modem. Neither laptop in connected to the modem via eithernet. how would I set this...
Hi There.. Please follow te below steps..
1) Connect your old computer to the wireless network. Nowadays most people use the internet through a wireless network. So basically, if you have wireless internet and you are able to get on the internet... that means you are connected.
2) Go into the networks settings. This is usually as simple as right clicking the network's icon and then clicking properties. What you want to do is turn on, "file and printer sharing" within the network
3) Now, go to the folders/data that you want to transfer. Right click or get into the properties of that folder. Check the box that says "share this folder with network".
4) On the new computer, connect to the wireless network. Under control panel or possibly the start menu, there should be an option for "My Network Places" or "My Network". In this folder you should find the data that you chose to share from your old computer. You can simply copy/paste or drag/drop the files to your new computer.
Now you are offset to transfer the files from one laptop to another...
Was this information is helpful. Kindly revert if this helpful..
Jan 12, 2010 | Westell Wirespeed LiteLine 6110 Modem
Hi could you tell me please how i set up a wireless connection on my bt home hub thanks
First you will need a wireless router.Once you have this you will need to take a conection from the existing hub to use as a source for the internet.Configure the router as per instruction.
Good Luck
Oct 17, 2009 | Computers & Internet
Connecting 2 computer
Your easiest way would be to go but a Switch and hook the two together then hook the switch to a single iternet connection.  (Most people think of a switch as a hub but a hub doesnt do as much.  You can usually pick up a lynksys switrch for 30 bucks)
If a sewitch is not an option then i would suggest getting anuther network interface card for the pc, put install it, and bridge the connection between the two network cards so the internet is comming in one then out the other to the laptob, then just hook the laptop into it.
short of that if you are looking to keep both computers on segfregated networks and then linkk them together then you are looking at a new network card for the pc and a usb to network adapter got the laptop then link the two togethter.
maybe it would be easier if you just transfered the files over the internet through a Ftp Clientlike cuteftp or blazeftp and not even link the two computers at all.  it may tak a little more time but it would be alot cheaper and alotr easier and if it s just small files you probly wouldnt even notice a difference.
Hope this helps.
Dec 08, 2008 | Computers & Internet
Adding internet to a network
How many computers? are you allowing any computer to have the smae rights, because if anyone does, you are going to have more Problems, let me know
Aloha
Kahuna
May 21, 2008 | Computers & Internet
3 com hub tp4 home network setup failure
There are several possible problems here, and more information is needed to identify which one is causing trouble. First, are you using a high speed dsl or cable internet connection? ...or is your Internet connection a dial-up phone line? This will have a significant effect on how your cables should be connected between the hub and the computers. Windows typically defaults to a 169... address when it is not properly connected to a shared network connection.
Jan 08, 2008 | 3Com HomeConnect (3C19261) 5x10/100 Mbps...
Internet conections
you will need either a usb 54MBPS or 108MBPS wireless adapter of any make that will connect to a usb port or a pci wireless card to fit in the pc tower on the motherboard.
Oct 06, 2007 | Linksys (WUSB54GCU) 802.11g/b Wireless...
Megxon X33 Digital Camera Logo
37 people viewed this question
Top Megxon Cameras Experts
Greg Cann
Greg Cann
Vladimir Frolov
Are you a Megxon Camera Expert? Answer questions, earn points and help others
