YSP-800 No power-up, Checked voltages at P/S input (ok) 3.3v output (ok) Suspect P/S is Held off Due to fault elseware maybe Software ? Can you help please. tvted.
  • Edward Jones Apr 25, 2010
    After changing C515 as you said, Every thing is now working O.K.
    Many Thanks
    tvted.
  • 560 Answers
Power failure mostly came from degraded capacitor C515 (22nF 630V pin distance 10mm), located at the side of the fuse. Replace that capacitor. Most people are having the same problem and their unit start working after replacing that capacitor. If you have the skill, tools and know where to buy Capacitor C515, you can do the repair yourself, otherwise, send your unit to a qualified technician.
Posted on Apr 24, 2010
Studio master 6.0 amplifier front LEDs blinks when switched on and no outputs ,I be checked the output transistors its all OK can any one help find the solution please.
It is difficult to troubleshoot this type of problem online. If the fault indicator is not on and the outputs are OK, then I would suspect something in the protection circuit. I would start by checking the supply voltage on the protect relay, relay coil (may be open), and capacitors near the protect relay. If the fault indicator is lit, I would suspect a leaky bias transistor is causing a dc voltage at the output.
Dec 13, 2017 | The Audio Players & Recorders
Suspect flyback fault but not sure....power takes several seconds to turn on again after putting off...the screen voltage is less than 100volt but focus voltage ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
May 07, 2016 | Televison & Video
Stryker x7000 light source. power Fault,i have checked Power Supply component main capacitor fuse and bridge rectifier all is OK but no display and out put,kindly help me please.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 01, 2015 | Televison & Video
My fuzzy logichas stoped spinning washes ok but no spin pls addvise if its easy fix thankyou
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.check for output when the cycles is in the SPIN mode, if absent the board is a suspect.
Check for moisture in the board, remove and reset all the connectors to the main board before the processor or the memory can be suspected.
Feb 06, 2013 | LG Washing Machines
Izip electric bike wont start
If the battery cells have been load tested and found OK then You need to trace the output voltage (using a voltmeter) from the battery to the controller to confirm you have voltage at the controller when the power is switched ON. If there is no voltage at the input to the controller then trace the voltage on components between the controller and battery, such as the switch and fuse and all the connectors.
If there is full battery voltage at the input to the controller then suspect the controller is faulty.
Jun 09, 2012 | Electric Cycling
No sound from my home theater and when i power on only ward philips and then disk shown it cant power off until you remove power cable
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Also check the +5 volt on the processor and if this section does not receive power or if the IC is faulty then the system can hang. check the processor input/ouput data .
Aug 17, 2011 | Philips HTS3410D/37 700W DVD Home Theater...
Suddenly the unit has failed - no power at all.
I have the same problem, fuse ok, plug ok and internal fuse ok. Sent it to reccomended engineer he said it cant bre fixed. only 3 year old, not happy
Sep 28, 2009 | Yamaha YSP-800 System
YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have the sony KDL 46 EX720 and got the code 2751 to work.
Jan 19, 2009 | Yamaha YSP-1 System
How do I connect a mac audio output to a yamaha sound projector?
NO!!! get a 3.5 male TRS to stereo RCAs to either the Aux input on the amp or the audio portion of the front A/V Aux. the audio jacks will be red and white.
Dec 04, 2008 | Yamaha Digital Sound Projector Home...
Yamaha ysp 800 setup
can you please help me i have no set manual for ysp-800 and can you assist me on how set the microphone up to get the best sounds thanks
Sep 04, 2007 | Yamaha YSP-800 System
218 people viewed this question
 Grubhead
Grubhead
