Question about Asko W6021 Front Load Washer
Not just your ordinary pintrap drain problem
Asko W6021, purchased summer 2003...machine won't drain. Pin trap is clear, I've pulled out the pin trap cover and let the machine finish the spin and drain into a bucket and the little plastic thing at the back (what is this called?) is still spinning and pump sounds like it is running, though not draining, I tried running a very hot cycle in case there was sludge or something, but nothing. When the machine is on drain a very tiny trickle is coming out of the outlet hose. However, this occurred immediately after two very successful (completely drained) washes, so is a sudden blockage of the outlet hose likely?
I am not mechanically knowledgeable so I need non-technical language on how to solve this/ identify parts/ etc.
  • 4 more comments
  • jessupclr Mar 24, 2008
    I do have the manual. I went and tried but could not get any of the paddles out as described for this process (the screw driver in the center hole did not help me in moving the paddle over so that they could slide out.) I'll have someone else try to see if it is just me, but suggestions are welcome
    I have checked between the drum and outer container. There is nothing blocking the drain hole that I can see or feel (I looked with a flashlight.) There is residue build up on the small hole to the side of the larger one but this does not appear to be blocking it.
  • jessupclr Mar 28, 2008
    Thanks; we got this resolved the old fashioned way... calling the appliance guy. I could not figure out exactly how to do what was suggested or which parts you were describing, though I think you were right... what he told us was that because there are no coins as small as dimes in Sweden, dimes occasionally get past the impeller into the outlet drain, which then is a continuous line to where it drains into the soil pipe. Sure enough; three dimes were found... luckily not too far along the line! All set.
  • jessupclr Mar 29, 2008
    I attempted to rate tech17's solution as inappropriate, (read: not useful and kind of obnoxious) but it didn't come across that way. greendude's solution was actually a solution, though I could not figure out on my own how to do it (my own problem). I am in the united states; read more carefully... I said they don't have coins as small as dimes in Sweden. Since that is where Askos are made, the traps don't catch them.
  • jim9161 May 10, 2009
    Thanks greendude! That was exactly the problem, A US dime was stuck right in that spot. Now the machine works great again!
  • robert samples May 11, 2010
    do you have your owners manuel for the washer if you do follow the instructions for removing an object from between the drum and outer container then turn the drm till you find the hole for the drain pump and make sure nothing id blocking it and let me know if you find any thing we will go from there if not then you can get a manuel from here http://www.askousa.com/customercare/manu...
    Sergeant:
  • 351 Answers
Check to see if there is a small coin in the grey drain hose that joins the pump also see if theres a coin stuck in the black sump hose to the pump.you will have to remove the front panel first.two screws underneath the front a one under the soap drawer.the paddles pull out put small screwdriver in the middle hole and pull hard toward you,they will come out also blow through drain hose to see if somthing stuck coins act like a valve and cause inttermittent draining problems,also check pump impeller isnt damaged it may look ok(white).hope this helps.
Posted on Mar 26, 2008
    President:
  • 1,314 Answers
Sorry i didnt know you were in sweden im in usa but yeah thats what i ment its hard to tell on this site if people dont post their locations
Posted on Mar 28, 2008
  • robert samples Mar 30, 2008
    well sorry jessepcl but i didn't see greendudes post when i replied to you i thought you were saying that you lived in sweden and had smaller dimes there this is a world wide site and most of the time people dont post their locations and it makes it difficult to help them as most of us are doing this for free you said that you had checked the pin trap so the next logical place to look for the kind of problem you were having was the tub drain hole for a foreign object blocking it some times and not others didn't mean to sound obnoxious or disrespectful in any way i thought you were saying you lived in sweden when i replied to you
We have a pin trap problem. The outer cover comes off exposing a plastic white facing that will not budge. There is constantly a rotten egg smell coming form the washing machine. I've drained the hose...
Here's How:
  1. Exterior
    Wipe down the exterior of the washing machine with vinegar or your favorite all-purpose cleaner.
  2. Tub
    Pour two cups of vinegar or lemon juice into the tub, and run the washing machine through a complete cycle on the hottest setting to remove odors, stains and detergent build up.
  3. Lid/Door
    Scrub around the edge of the lid/door with vinegar to remove mildew and detergent build up.
  4. Bleach and Fabric Softener Dispensers
    Remove the bleach and fabric softener dispensers, and scrub them in the sink. Then, dry them thoroughly and return them to the machine.
Tips:
  1. To prevent mildewing, leave the lid open after you finish a load to allow the washing machine to dry out.
  2. Commerical fabric softeners leave build up in the machine. of choice, and the inside of your washing machine won't need to be cleaned as frequently - if at all.
May 17, 2011 | Asko W6021 Front Load Washer
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
The pin trap will not screw back into the washer
Check you have not pushed anything into the pump, also clear any limescsle away
Feb 02, 2018 | Asko W6021 Front Load Washer
Cleaning the Pin Trap
I also had this problem. Here is what I did. When the white cover comes off, it exposes the white circular facing. That's ok, once we get the pin trap out, the cover snaps back on. What has happened is that the pin trap is so full (of money in my case) that it is jammed. The facing has an indentation, but you can't get a grip on it with something like pliers because pliers squeeze, they don't spread. I found a tool at the hardware store called "chain pliers" that when you squeeze them, the jaws spread. There were multiple indentations on them, the first set were pretty thin and I was afraid I'd break the plastic lip on the facing. So I cut the tips of the chain pliers off with a hack saw. Once I got a grip on the facing, I jiggled it in and out until it released.
Sep 04, 2008 | Asko W6021 Front Load Washer
I have an Asko 10505 Front Loading washing machine. It will spin but ill not drain.Where do I look on the Machine to see if there is a problem with the drain pump. I am in Australia
front right corner the pin trap turns to the left and pulls out it may be stuck pull hard.also check the yellow impellor to see if it is loose
Aug 25, 2008 | Asko Washing Machines
Water constantly in pin trap
I had this problem and found out there was something stuck in the drain hose.  It also made my clothes smell sour.  Unhook your drain hose stretch it out straight, run water through and maybe snake it if need be.
Jun 29, 2008 | Asko W6021 Front Load Washer
Front drain plug
I have similar issues with my Asko W660. Once it was a key stuck between the inlet to the pin trap and the trap itself. I got it out by jiggling and poking into the trap area with a narrow strip of plastic. Mostly, though, it just requires a stronger grip on the door to the pin trap--the little handle is slippery, and hard to get a good grip on. Try making a grip out of a piece of duct tape, or grabbing the handle with pliers.
Jan 05, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
535 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
