Question about Cuisinart DCC-1200 Coffee Maker
Water will not pass through seems clogged - Cuisinart DCC-1200 Coffee Maker
Sometimes coffee grounds get into the intake if you don't use the intake filter. Unplug, set the pot aside and then turn the coffe maker upside down in a sink with a good hose sprayer. Direct the water up into the intake side of the coffe maker with the filter out.
Then refill and see if water will flow through. If it works, run vinegar or a pot of water with a tablespoon of dissolved baking soda (dissolve in pot first or it will clog the coffee maker).
It worked for me.
Posted on Apr 24, 2010
  • martytaylor3 May 18, 2011
    This really worked great. Thanks for your advice.
No cold
dear Ali you have a pretty vauge question but i will start with an assumption that you have no cold water going into the tub when machine calls for it. start at the wall where the water supply comes out of the fausct -if it comes out there and it seems like the pressure is as strong as the hot side check the hoses for blockage. lastly make sure there are no clogged screens in line or on the back of the machine. generally the water control valves fail and will not let the water pass. replace that and you should be golden Cheers Denny
Nov 24, 2015 | Washing Machines
My freezer is collecting water in the bottom just below coils how do i repair
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRS6R4EQ4 is collecting water in the bottom of the freezer, below the coils. I also see that you think the drain is clogged. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water is collecting. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Refrigerators
Amana furnace model amv9 has water dripping from the exhaust outlet. the exhaust doesnt seem to be clogged and the overflow for water to run into doesnt seem to be clogged. water is makign its way int
You did not say if you have a dehumidifier or air conditioner installed on this unit. If those are not installed on it then the only place moisture could be coming from is down the exhaust connection for the flue. If one or both of those items are installed then the issue is the drain trays might have debris built up that you cannot see.
Mar 23, 2014 | Heating & Cooling
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Sep 18, 2011 | Refrigerators
GE tfx22r leaks water out bottom of freezer door. Bottom of freezer covered with ice. Vacuumed and cleaned evaporator and coils. ice maker water is shutoff. Water seems to be coming out from behind crisper...
defrost drain is clogged, remove back panel, and pour hot water down drain and blow it out with pressure of some sort until water passes freely
Nov 01, 2009 | Refrigerators
My 98 mazda seems to not be circulating the water correctly and we went througheverything and the water pumps new the head gaskets new theres no leaks. so we are stumpd and really need help
If the coolant isn't flowing with a new water pump; your thermostat isn't working correctly, or your radiator is clogged and not allowing the flow to properly pass through the fins.
Jun 21, 2009 | Mazda 626 Cars & Trucks
Why are my ejected coffee pucks very wet? Seems
You need to be sure the removeable grinding surface is clean and not clogged. If it is not clean, water has problems passing through the screen and the water cannot escape, staying in the puck...
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
IRobot 5800 Scooba Vacuum dirt not going into the fliter basket
You can try rinsing the tank very thoroughly with warm water. Be very sure that you rinse the four ports on the underside of the tank (one round, two oval, one curved like Scooba's filter) very thoroughly, because all the dirt and dirty water moves through those openings and can clog things up.
Fembot
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
Leaks from top
Yes it goes to the pan.. you can ues a hair dryer but do not leave it unattended.Or your drain line is clogged to the pan .
Dec 07, 2008 | Home
Attempts to fill w/ water but won't...
you can check the inlet solenoid coil. maybe there is no power coming to the coils or if there is power, the coil is burnt.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cuisinart DCC-1200 Coffee Maker Logo
2,535 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
