Question about Sharp R-23GT Microwave Oven
Timer counts down but does not microwave
Pushing the door switch 3/64 of a inch causes it to come on
but this distance varies
Thank you
Jay
    Habit-Forming:
  • 193 Answers
You have a problem with the door interlock switches and it should not be used till fixed.
Posted on Apr 24, 2010
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
We have a Frigidaire FMV156DCC that is about 3+ years old. as of last night when the door is closed and the time is selected one of 3 things happen (or doesnt happen) 1. is nothing, just a dark...
I would replace the door switches and set up the door gap to 1/8" just enough to alow for a little play.
Setting the door square is acheived by slackening the lower door hinge and re tightening it when the door is square.
Hope that helps.
Jan 03, 2011 | Frigidaire FMV156DC Microwave Oven
My GE 1660 profile microwave oven will not cook or rotate, but the timer reduces in time. I have tried to gently press up or down on the door in case it is a door latch issue with not change. Also it keeps...
Check the door safety interlock switches. If they are burned (because you frequently open the door while the oven is running) they tell the magnatron that the door is open (forget what you know about the door) and not to run that magnatron (which produces the microwaves that actually heat the contents of your oven).
Check the switches with a ohm meter. Remove the cover to find the switches near the door latches.
Thank you for your interest in FixYa.com
Dec 26, 2009 | GE JE1660 Microwave Oven
Timer counts down but nothing happens
one of three of your micro switches that monitor your door is bad. easy to fix. remove control panel and u will see the switches that the roll cam for your door hits.
Apr 20, 2009 | Dacor DMT2420SS Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Frigidaire won't run
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
Timer will run, but won't cook
Sharp R-23GT Microwave Oven Logo
197 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
