Question about Tissot T Race T90444631 Watch
My tissot T010.417A the second hand is moving but the time doesn't...this only started last week, the watch was working fine since I got it in January.
  • 14 Answers
SOURCE: Tissot wrist watch goingin reverse since new battery fitted
bikie,
It would be easier to tell you more if the age of the watch was posted, but not knowing that I am going to assume it is less then 3 yrs old and in good shape. He goofed! Never be afraid of asking someones experience level when working on something that belongs to you, find out if they are just a clerk in a jewelry store and are getting paid minimum wage and care more about their paycheck then your watch, OR if they have been doing it forever and care if you come back again! "IF" the watch is older then I assumed, or in questionable condition (a few bumps and scratches) then it may have nothing to do with the fact that the battery was just replaced, it really could be it's "time" to expire, pardon the pun!
Posted on Dec 01, 2007
SOURCE: tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Posted on Jan 14, 2008
SOURCE: the second hand is not moving
Are you sure the big second hand is not used for the chronograph? I once had a watch that did exactly that. There was a small second hand in the lower left which was the normal secondhand, while the big second hand was used only for the chronograph. It annoyed the cr*p out of me, so I always had the chronograph running, just so the second hand would move.
Posted on May 24, 2008
escapement
  • 2334 Answers
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Yes, pulling out crown prolongs battery life, but this is only for allmost unnoticeable period of time.
With the seconds hand there are only one solution- you have to take your watch to the nearest watchmaker as you will not be able to deal with it without appropriate knowledge and skills.
There can be two reasons why the seconds hand is jumping:
1) Fault within integrated circuit ( watch 'brain' is not giving an impulse in a specific period of time),
2) Few teeth may be damaged on second wheel as well as there can be tiny dirt particles sticking onto it.
Both need attention of professional.
If that seconds hand do not annoy you too much, wait till the watch needs battery replacement and then replace battery and check the watch at once. It will be cheaper then to do both jobs separately.
Posted on Dec 20, 2008
SOURCE: my Tissot Watches second hand jumps 3-4 seconds bursts.Why?
The second hand jumping three or four seconds .I have had this same problem and found out that its i sign of wanting a new battery.Mine is now perfect
Posted on Feb 26, 2010
Does the Tissot PR516 T044.417.21.051.00 use a battery? My second hand is not moving when i start the timer and the night vision is terrible.
Yes, it does require a battery. I believe a 394 is the correct one to fit, but I'd suggest you took it to a professional rather than attempt a battery change yourself. I hope this helps.
Oct 13, 2015 | Tissot Watches
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Aug 04, 2011 | Tissot PR50 Sport Chronograph # T34152852...
I have a Tissot PR 50 Chrono,,, I have replaced the battery 3 times in the past two years. Then it got to where the second hand only would run. Now, nothing. If I hold the lower button in, the second hand...
When a battery is replaced, but doesn't last long, that indicates an internal electrical problem with your watch. The fact that the hands are operating incorrectly is also an indicator that something has shorted out inside the watch. I wish whomever sold you batteries 2 & 3 knew what they were doing!
As the Tissot is a fairly expensive, quality watch, I would suggest finding a locally-owned, high-end jeweler to recommend a watch repair shop, or alternatively, go online and Google "Tissot repair" to find an authorized repair shop. Good luck! Sorry I couldn't help you.
May 03, 2011 | Watches
Setting my Tissot touch Navigator 3000
Per the manual: http://support.tissot.ch/usersmanual/140-en.pdf
When your battery begins to die, the hands are no longer synced.
After replacing the battery, go into local time mode (pressing the center of the crystal) until "Set" appears. Press the crown. Scroll to "ECO BAT", press and hold the crown for 5 seconds until "SYNCHRO" appears. Use the "+" button to move the minute hand and the "-" to move the hour hand until they are in the upright or 12:00 position.
Either press the crown again or wait until the watch automatically leaves the Set mode. Your hands should now represent the local time.
Feb 08, 2010 | Tissot T Touch Navigator 3000 T96.1.478.32...
Tissot PRS 200 My watch is not keeping time. It is not a batery problem. I have been told that it is because the chronograph is always working. How do I shut it down ?
Your true actual time second hand is on one of your subdials. That big "second" hand is really your chronograph seconds timer. It should start and stop when you depress one of the plungers/ buttons on the side of your watch.
Again, that big hand does not need to be turning all the time (or ever if you never use your advanced stopwatch/ chronograph). The true seconds hand is very small on one of the smaller dials.
Good luck, I hope that's all it is
Oct 23, 2009 | Tissot PRS 200 Wrist Watch
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Dec 20, 2008 | Watches
Display and all functions other than time have ceased to function
I had this problem after the battery was replaced at a jewellers. It turns out they had used the wrong battery as it only lasted a week.
May 16, 2008 | Tissot T-Touch T33759851
Tissot PRS 516
Your Tissot watch is a chronograph. The large second hand is for the stop watch only. There is another second hand by the six that is for the time. To get the large second hand to move hit the top right button, that works the stop watch. If you already knew this and your large second hand is not going around then there is something wrong with the watch either a battery or needs service.
Mar 08, 2008 | Tissot PRS 516 T91142651 Wrist Watch
Tissot T-Touch-Works fine until just about the end of the warranty
I suggest writing to Tissot in both your home country and in the head office in Switzerland. Use both email and paper letters. If you can provide documentation of the attempted fixes that will really help your case. Since you had a history of problems you have every right to ask them to stand behind their product. Perhaps there is a new warranty on the replacement movement, for example. You have nothing to lose except a bit of time, paper and postage. You could even ask your dealer to back you up with this -- he or she will still get paid for the work if Tissot agrees to extend the warranty.
Nov 23, 2007 | Tissot T-Touch T33159851 Wrist Watch
Tissot T Race T90444631 Watch Logo
510 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
