Question about Whirlpool Duet GHW9150P Front Load Washer
My kenmore front load washer has a thumping noise?
  • 5,081 Answers
First, make sure that the dishes aren't rattling around inside the washer. Believe it or not, your Kenmore Front Load Washer user's manual will have instructions on the proper procedure for loading it.
Unplug the washer if possible and, when it's dry and empty, remove the bottom cart to look at the drain port near the back of the washer's interior. Sometime food scraps or silverware can get lodged in the port's mouth and rattle around every time the washer runs. The only time you should ever need to call a repairman about this problem is if the noise only occurs at the start of the wash cycle and makes a low thumping noise or a rapid-fire clicking noise. These are both indicators that the inlet valve is broken and needs to be swapped out for a new one.
Its your inner tub bearing that is causing the problem,it is going bad and will continue to do so. You have to buy the whole inner tub in order to get a new bearing or you could have someone press it out and find the part number to replace it with.
Posted on Apr 24, 2010
Load noise when washer spins
can you discribe the noise is it a rumbling sound or a thumping sound
Nov 29, 2011 | Kenmore HE2 Plus Front Load Washer
Continues to thumping sound only on the spin cycle on my tumble action washer (front loader).
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 15, 2011 | Kenmore Kitchen Ranges
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
Washer Problems
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
Once it goes to the last spin cycle ,( the fastest one) it starts making a thumping sound . could it be a belt or bearing?
Washer Problems
heatman101
Jan 13, 2011 | Kenmore HE2 Plus Front Load Washer
I have a kenmore front load washer model 970-c42072. I'm experiencing a loud noise in the drum on the spin cycle even when it is empty no matter what setting (slow normal fast) What would be the...
If you turn the inner wash drum by hand, what kind of noise do you hear? If it is a thumping kind of noise, it would mean that the spider support arms are broken. If the noise is a loud rumbling sound, similar to a jet engine when it is spinning, it would mean that you have a bearing seal failure and the bearings need to be replaced. Either problem is a big job to fix since the entire washer needs to be taken apart. Get a few estimates before deciding whether it is worth fixing. Sorry.
Sep 01, 2010 | Kenmore 44072 Front Load Washer
Loud banging noise during spin cycle of my front loading kenmore
If you spin the drum by hand, does it make any kind of thumping or banging noise? If it does, then you probally have a broken spider arm(s). This is very expensive to repair, unless you are handy, it may not be worth fixing. The link below shows the problem and how it can be fixed.
http://www.jimwilliamson.net/misc/2006-08-28-front-load-washer/index.html
Dec 23, 2009 | Kenmore Washing Machines
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Thumping and banging
washing machine making noise, remove water but doesn't spin
Jan 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore front loader model 417.29042992
check and make sure the washer is LEVEL otherwise when in spin, it may "walk" across the floor. also if it's not level then the tub will "tilt" in one direction and may contribute to the thump, thump.
Aug 23, 2007 | Kenmore 43042 Front Load Washer
Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Dec 07, 2006 | Kenmore 44102 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal De
