Question about GE 30 in. JGP336 Gas Cooktop
Unable to properly adjust flame on GE gas oven. Able to properly adjust flame on top burners (either blue flame or blue flame with small yellow tip). Having problem adjusting flame for oven/broiler use...flame is yellow.
I have a GE Model Cooktop JPG337BEJ3BB and the burners are flaming to high. How do I turn them down?
Posted on Aug 13, 2010
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Yellow flame
The problem is with the orifice leading to the burner. If it is not centred then you will get yellow flame. Or you are impeding the flow out of the burner and it is not mixing properley. I would pull the burners apart and make sure everything is clear and the orifice is centred.
Apr 14, 2014 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Hi - I have a 4 burner GE gas cooktop. The clicking sound comes from all the burners but 2 of them are difficult to light. If I hold my hand over the top ... they will light! Is there an adjustment that...
Usually this happens if something has been spilled or a pan overflowed and is partially clogging some of the burner holes. Make sure the burner holes are clear and try poking them with a sewing needle to make sure. I am assuming the flames are a nice blue color and not a lazy yellow or yellow-tipped. If there is some orange, that is usually an indication you are burning off some food and will need to be cleaned. If that doesn't appear to be the issue, then let us know and we'll dig deeper. Douglas
Sep 18, 2010 | GE 30 in. JGP328 Gas Cooktop
Large yellow flames after the oven is on and getting up temp
The needle maybe damaged or missing inside of the hood, unscrew the hood and remove it, look at the needle and make sure it is intact, put a little liquid soap into the hood threads and screw it back on until it bottoms out, it will be much easier to feel it bottoming out if it has lube on it, if this does not work, call them and have them send you a LP specific hood rather than the adjustable type.
Jun 13, 2009 | General Electric PGS975SEMSS 30 in. Gas...
Converted a ge gas to lp. the oven and broiler has too much flame
You must close the gas valve orifice. There is a gas valve (silver or grey colored rectangular shaped piece which feeds the burner(s)) that has a brass or gold-colored hex nut. This nut (1/2 inch) needs to be tighten down clockwise to the stop point. This will regulate the flame.
Dec 21, 2008 | GE 30 in. JGP336 Gas Cooktop
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
GE 30 in. JGP336 Gas Cooktop Logo
729 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
