Microsoft Digital Image OEM
I had to do a Factory Re-Install of my Systemax Computer using the Phoenix Recovery Program that came on the Computer when I bought it. NOW my Microsoft Digital Standard 2006 will not work correctly as before. I can do Everything in my Digital Program EXCEPT Editing the images in putting the frames around them. I have to put the Digital Image Disk in my "D" Drive before I can do it. I have Reinstalled the program by using the Digital Image Disk but nothing helps. It states that everything was Installed Corectly, but I am having this problem that I did not before the re-install. I can use it with the disk, but it is a pain everytime i want to work on my images to load the disk and remove it when I am done especially if I have to stop and do something else and go back to the Editing. Any help would be appreciated. Thank you in advance,
James
  • jamerogers Mar 23, 2008
    I will try this ASAP. I did a Typical Install but will do a Full Install this time.The Error i am getting without the disk in is tlling me that I need a PIP\PI Folder installed BUT it is Listed in the Program Files where it is downloaded. i will try your suggestion in a few and thanx
    James
    Scholar:
  • 178 Answers
When you install the program, does it give you more than 1 install Option? Most programs will give you 3 install options depending on how much disc space you want to use for that program. Typical, Custom, Full. If you haven't done so, I recommend uninstalling, reinstalling using the FULL install or Custom so you can pick and choose which features aren't necessary for you to have. If this works, excellent, it it doesn't, I am sorry, but hopefully it gives you a little bit of insight.
Posted on Mar 23, 2008
Restore factory settings without disk
when you first power on the machine hit F11 (for most machines) on the keyboard repeatedly until the recovery screen pops up. Click on advanced options, click system recovery, then click OK when prompted. the recovery process will begin and take about 25 minutes on a 5400rpm hard drive. then you must reinstall everything that isn't factory.
NOTE: THIS WILL ERASE ALL DATA THAT ISN'T PREINSTALLED. AFTER THE RECOVERY, YOU MUST INSTALL THE INTERNET SOFTWARE, VIRUS SOFTWARE, ALL UPDATES (THERE'LL BE A LOT!!), AND PERSONAL SOFTWARE AND HARDWARE. BACK UP ALL DATA BEFORE YOU BEGIN. ONCE THE RECOVERY PROCESS STARTS, IT CANNOT BE STOPPED, OR THE SYSTEM WILL GET CORRUPTED. :(
Hopefully this will help.
P.S. Give this recovery process about a day to get it over with. Don't rush it for best results, and use pc decrapifier to remove all the bloatware and trial ware installed by hp on your pc.
Mar 10, 2014 | Systemax Computers & Internet
Factory restore
if you are running windows7 you can use the backup tool in windows to make the image but remember to make a boot disc this backs up your registry and you will need it to re install your windows image.
Jan 20, 2014 | Systemax Venture PC Desktop
Samsung Sens X06 bios fail
see this steps and proceed .God bless you
    • 1 Download a crisis recovery program designed specifically to restore damaged or otherwise non-functioning copies of Phoenix BIOS. Read the instructions for using the recovery program to make sure that no specific changes or configurations need to be done to it before it is used.
    • 2 Place the Phoenix BIOS recovery program and its files onto a blank disc or a USB drive according to the program's instructions (this usually simply consists of extracting the files from an archive.) Once the program and its files are in place, insert the disc into the computer's drive or plug the USB drive into an available USB port.
    • 3 Hold down both the Windows key and the "B" key on your keyboard and press the power button on the computer. (On some laptop computers, you will need to press the "Fn-B" keys instead.) Wait for the disc drive light or the USB drive access light to start flickering to show that the computer is accessing the Phoenix BIOS recovery program, and then release the keys.
    • 4 Wait patiently while the Phoenix BIOS recovery program overwrites the damaged sections of the motherboard's current BIOS installation. Depending on the computer and the recovery program used, the computer may or may not reboot once BIOS recovery is complete. If the computer does not reboot on its own, wait at least 10 minutes before manually restarting the computer to make sure that you do not interrupt BIOS recovery. Eject the disc or remove the USB drive before rebooting to prevent accidentally reloading the recovery program.
    • 5 Reboot the computer and watch to make sure the Phoenix BIOS screen appears as normal. Once the BIOS loads properly, your operating system should launch as normal.
Oct 18, 2012 | Computers & Internet
I need to restore my computer using the Function keys and do not remember which Function key(s) to use
If you are certain that there is a recovery partition with a factory default image then your user manual should include the instructions on how to access it.
HP normally uses a backup and recovery software rather than a recovery partition with a default image. This setup requires that you make restoration discs before using the computer in case something goes wrong.
Alternatively, you can keep restarting the computer and hit a different function key each time in an attempt to access a recovery program.
If you own a copy of Windows you can also just put in the disc and install Windows to your C: drive and over-write the existing installation.
As a last resort, you can order a set of recovery discs from HP's Customer Support.
Jul 06, 2012 | HEWLETT-PACKARD Compaq DC5850...
How do you bring back your computer to its original state like when you first bought it
To put the original factory software back on your computer is called recovery or system restore, and it can be done a couple of ways.
Computers used to routinely come with a recovery set, one or more CDs containing the factory image. Those discs are largely a thing of the past now, but you may have a computer which included them. You put the disc (or the first one) in the CD drive, boot the computer from that drive, and the recovery process proceeds on its own.
Since nearly every computer sold today includes a disc burner, recovery CD sets aren't provided. Instead, there is a utility program installed that lets you make your own recovery set. Some people never get around to making these discs. If that happens and you want to restore the exact factory software, you need to check the manufacturer's website to see if you can purchase a restore set. Some manufacturers offer them for sale, but not many. And they are usually expensive.
Another option is a recovery partition on the hard drive. The factory image is stored there in a compressed form. In a computer with a recovery partition, pressing the appropriate key or key sequence boots the computer from there, and the recovery begins. If your computer shows a message like "Press F10 for system recovery" or something like it, there is a recovery partition.
If you don't have a restore set and there's no recovery partition, you can install a fresh copy of Windows using a regular Windows installation CD. You just need to make sure you're installing the same version that was on your computer when you bought it. When the installation asks for your product key, you would find it on a sticker somewhere on the computer. If you install Windows this way you'll need to activate it, and you'll need to install any driver software needed for the system hardware (video, sound, and network interface at least, plus whatever else is in your computer). You can download these drivers from the computer manufacturer's website. You also would need to install any application software, since none of those that were preloaded will be there. This isn't a bad thing, though. Most computers come with a lot of mainly useless software preloaded that you don't need. With a clean Windows installation you can put on just what you really need, and you can choose which program to use.
I hope this has helped. If so, please take a moment to leave a thoughtful rating. Thanks for using Fixya!
Oct 22, 2010 | HP Compaq nc4400 1.83GHz Core 2 DUO T5600...
My ms word or excel files are not opening
hi you need to re-install ms office.your existing program has become corrupt.
Aug 27, 2010 | Microsoft Office Professional 2007 Full...
Systemax factory restore - how?
Tap F4 repeatedly to launch the recovery console on SystemMax Machines with the recovery partition still intact. Then you should be able to restore the machine to factory defaults without a CD.
May 05, 2009 | Systemax Venture PC Desktop
Re: Need to do a factory restore
Hello:
REcovery discs can do the task by restoring it to the factory setting. you can insert it directly to the DVD/CD ROM and then boot the pc to the ROM. and the follow the onscreen instruction.
however; if you have recovery disk then you have to provide windows installation disk and install it to the your hard drive.
installation of windows information is found here:
http://support.microsoft.com/kb/316941
may this help you.
melnavz
Sep 03, 2008 | Systemax Venture PC Desktop
Deleted picture
Hey LucyBe,
Yes there is a way to get your image back. You would need to install a data recovery program on your computer, which there are multiple free programs out there that would suit your needs. Once this program is installed connect your memory card to your computer with a card reader, and as long as you haven't overwritten the deleted image you should be able to retrieve it using the recovery software.
Sincerely,
Allan
Go Ahead. Use Us.
May 13, 2008 | Samsung NV3 Digital Camera
Computers & Internet Logo
David Payne
David Payne
