Question about Car Audio & Video
Car stereo does not work - Car Audio & Video
  • blingbling81 May 11, 2010
    more info please
  • 86 Answers
Get a new unit.
Posted on May 30, 2010
Everything works on my stereo system,but there is no sound
Car Stereo Head Unit Install ** No Sound ** Amp Not ...
? 10:41
https://www.youtube.com/watch?v=wQ9bSdJGMjg
Mar 23, 2014 - Uploaded by PSYCHOTICNORMAN
Video for those who installed their head unit correctly, but got no sound / factory amplifiers not turning on. ... Car Stereo Head Unit Install ** No Sound ** Amp Not Turning On ** work around. ....Did everything to the letter on a 2001 Chrysler Town and Country and while I do have audio, my audio is cutting in ...
Everything works on my stereo system,but there is no sound ...
www.fixya.com/.../t26059653-everything_works_stereo_system_but_no
1 hour ago - everything works on my stereo system,but there is no sound lxi 4cd canger - Chrysler 2001 Concorde question.
Chrysler Concorde radio works but no sound Questions ...
www.fixya.com > ... > Cars & Trucks > Chrysler
Chrysler Concorde cars & trucks radio works but no sound questions and answers. ... Fixya - Solutions for Everything ... My 2002 concord lxi when ... CAR STEREO HAS POWER BUT WILL NOT OPPERRATE ... Question about 2001 Concorde ... ...sound from radio thru speakers Is there any popping when playing a CD or ...
Jan 19, 2016 | 2001 Chrysler Concorde
Changed car battery and the dual car stereo won't work now. reset the stereo and the security light is flashing and the stereo still won't work?
Your solution depends on the brand and model number of your stereo system I take it your stereo system is Ruth is included in a anti-theft device this is highly technical and manufacture specific you need to follow the instructions for installing the system initially somehow your system lost sanity. You need to unplug the fuse that goes to your stereo turn your stereo switch on and let it sit for a day then return with the users manual and go through the installation sequence that has to do with connecting power and setting default settings other than that you have to contact the manufacturer
Nov 25, 2014 | Dual Xdma6540 Car Stereo Receiver
How to can i replace stereo
see this : God bless you
Review your car's owner's manual to see if it has any tips on removing the current stereo. It may have a diagram of the wiring and the area where the stereo is installed.
  • 2 Disconnect the battery to avoid an electrical short while working with the wiring.
  • 3 Use a screwdriver to remove the retaining screws holding in your car stereo. Grab hold of the stereo and pull it toward you to remove it from the dashboard.
  • 4 Get a pair of DIN tools to slip on either side of the stereo, if the stereo connects to the dash using spring clips and bolts. These thin tools slide in easily, release the clips, and allow the stereo to come out easily. You may need to remove dash panels when bolts hold in the stereo. Take out the bolts and screws that hold the stereo in, and then simply pull it out.
  • 5 Look at the wires on the back of your car stereo. You should see 2 wires attached to the stereo. A wiring clip protects the stereo from vibrations and holds the wiring harness steady.
  • 6 Pry the wires up from the stereo and loosen them using a pulling/pushing motion. After working the wires back and forth, you should be able to pull the wires straight out.
  • Sep 28, 2012 | 1996 Toyota Tercel
    Stereo and interior light and central locking r not working
    alot of new cars have the imobilizer in the stereo ,for you sake i hope he didnt chop off the old stereo plug ,he needs to refit the old stereo ,
    Apr 09, 2012 | Mitsubishi Pajero Cars & Trucks
    OEM Stereo
    If your stereo was working fine prior to the hot lead to battery being replace and now the stereo is on, but only static. It most likely is some how they disturbed the lead that goes from the stereo to the battery. I believe it is a ground issue. The stereo has to be grounded properly to have it work proper as well as to the antenna. Now, I believe what happen is that when they disconnected the battery, it trigger off the stereo, or they disturbed the lead to antenna or ground to the stereo.
    I would try a couple things. I would unhook the battery lead again, and let sit for about 5 minutes. Re hook up and see if it works proper, If not, then trace all wires from radio to power source and grounds. I hope this helps Mike.
    Oct 22, 2011 | 2004 Chrysler Concorde
    Car stereo not working
    somthings wrong with your ignition wire run your stereos power on a toogle switch
    Jan 08, 2010 | Kenwood KDC-MP205 CD Player
    Stereo problem
    What kind of stereo, probably a wiring problem.
    Aug 12, 2009 | 2002 Dodge Durango
    Changed car battery and my sony stereo wont work
    you probably need to check all your fuses.
    May 05, 2009 | Car Audio & Video
    Powering car stereo using AC to DC power converter
    your power supply may not have enough power to run the radio.
    Mar 31, 2009 | Car Audio & Video
    Fitting a Kenwood car stereo to a 2003 Toyota Hilux ute, all works well until aerial lead plugged in, then immediately the fuse blows that feeds park lights, dash lights, instruments etc. Car stereo works...
    The vehicle chassis ground or negative is opposite to the stereo. The aerial is vehicle chassis ground (earth), when touched to stereo results in direct short. If the Hilux is positive ( + ) chassis (earth) and the stereo is negaitive ( - ) ground, there is the short. If this is the problem, either replace with a compatable stereo or compatable vehicle.
    Dec 27, 2008 | Car Audio & Video
    Car Audio & Video Logo
    37 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
