Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Pre ground Coffee is very weak, using beans is sour in our Magnif
We have a DeLonghi Magnifica. I've cleaned it thouroughly. We've had it for 3 years and it's been great, serviced it once. We stopped using beans because it was tasting so sour. We now find with grounds it's very very weak. Our water is pre-filtered and we have tried many different coffees. What can we do?
SOURCE: Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Posted on Feb 06, 2009
kram26
  • 544 Answers
SOURCE: delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Posted on Mar 21, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Lately whether I put in pre-ground beans or whole
If water is leaking from the very bottom of the machine, your unit is broke and you need to call Cuisinart. If it is just overflowing the caraffe/basket:
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi Magnifica EAM3400 When using pre-ground coffee I get the message; Grind too fine, turn steam knob. I do, but nothing changes. I pull out the diffuser, clean out the coffee, try again with beans -...
That is the reason the old owners gave it to you . You have to change the circuit board for it and it is as expensive as a new unit plus the labour and shipping .
Oct 30, 2013 | DeLonghi Coffee Makers & Espresso Machines
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My delight magnifica is now grinding too much coffee causing lots of excess falling into machine. How to I adjust the grinding time?
I had this same problem and discussed it with DeLonghi customer service. My machine was grinding 20 seconds for a double shot and ground coffee was coming out of the top and spilling over inside what a mess! DeLonghi thought it was potentially a problem with the control board - grinding time too long - which is an expensive repair. I also called the local factory-authorized service and described the same problem. They asked what kind of beans I was using and I answered Starbucks espresso. They said that Starbucks is too oily, clogs the machine, and that I should try beans that are lighter. I also checked with an engineer who used to work at Starbucks and he made the same guess. I tried an Italian roast espresso from a local market and it worked! I've had no problems since. The new beans cleaned out the oils and I'm getting great shots. This is a good machine, but is best making single shots.
Jun 11, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My grinder spins but no coffee powder coming out. I tried to open the top cap to vacuum out the beans and cleaned it with a brush and so, but still no coffee powder coming out from the grinder. What can i...
This happened to me when I first used my machine and I had accidentally pressed the button for ground coffee (the button on the front with the coffee spoon pictured) - when I turned this button off it worked perfectly and has done for over a year now.
Mar 28, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Can you grind hazelnuts with the coffee in our 3000 magnifica
I would not do this as hazelnuts are oily and will probably gum up the grinder.
What you could do is but a few ground hazelnuts in the pre-gound chute at same time coffee beans are grinding. These will go into brewer unit at same time as coffee.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I cleaned my delonghi magnifica and now nothing works. neither water or coffee comes out.it is just out of warranty unfortunately. help!
have u switch it on on back cover ??? ummm make sure u have the bucket sat in correctly .....and tray is in properly... have you snapped off the peg on the rear of the bucket for wast ?? its located rear of bucket. bsc appliances bristol 07779933829 postal service too.
Feb 08, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My delonghi magnifica bean to cup machine blows fuses
at a rough guess when you twisted the switch you have shorted out the power wire to the ground wire creating a dead short
take it to an appliance repair shop to fix what you broke
Sep 08, 2017 | DeLonghi Coffee Makers & Espresso Machines
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
108 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
