Question about LG WM2688HWM TROMM SteamWasher
For a few weeks now there's been a damp smell coming from the machine, we've used a cleaner which got rid for a few days but now it's back,how can i get rid of the smell
  • LG Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
Posted on Apr 26, 2010
Dog urine smell
Use a mixture of water and vinegar. About 50% for each. Use a handheld carpet cleaner to get rid of the excess after you let the vinegar/water mixture sit for a few minutes. The vinegar smell will disappear after a day or two.
Jun 27, 2013 | Dogs
Why do my clothes have horrible smell
Front loader? Welcome to our hell.
Seriously though - it's not that bad. You need to have a different mindset with these machines. First, throw away your old detergent. You've GOT to use the type with the HE logo on it. Really. There is a difference.
Wipe out any standing water in the gasket between the drum and door opening after the last load of the day.
Leave the door open slightly to allow air to flow around between washes.
Open the other doors for detergent, bleach, etc. between laundry days.
Don't use liquid fabric softener. Use dryer sheets instead.
Run a small, empty load with hot water and bleach ONLY. No clothes, as your last load for the days that you do laundry.
Use a product like Affresh, once or twice to rid the washer of existing smells. You can use Affresh any time the smells start coming back - and follow the suggestions above.
I hope this helps you as much as it helped me when I learned it! Good luck!
Sep 22, 2011 | Hotpoint Washing Machines
Hi I've had my machine for 8 months and the drum smells. I have tried adding Calgon to the wash over the last few washes but no difference. I've a water softner so didn't think I would need...
Hi Diana from retired Englishman in SW France,
You are lucky having a water softener; we don't (yet)! Calgon is very good at getting rid of calcium/limescale but does not necessarily assist in getting rid of smells. Here are my pre-typed guidance notes which should help you rid the drum of such ;-0)
By the way it is still a good idea to carry on regularly using some sort of calcium/limescale removing program, maybe each month. This should ensure that the heating element remains clear and working at full efficiency.
Bad odours could be coming from a few places.
  1. the plumbing u-bend of the washer's room or
  2. the fact that there is 'foul' water being left in the drum.
  3. No washes at 90 degree+ !
I would suggest checking the plumbing u-bend for trouble first, then following the notes on checking and cleaning the drain filter and the drain pump to ensure there is nothing 'obnoxious' hanging around the two of them! Finally run the occasional 90+ wash, or use specialised powder/fluid, designed to kill bacteria at lower temperatures.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 07, 2011 | Washing Machines
Hi, i ve got the refrigirator model # MBB1952hew, and for about 2 weeks to a mounth now it has a really bad stinking odor, my husband says it might be from the electrical oils inside. but i ve never...
Hi Franny. Welcome to FixYa. I am Kelly
Get yourself 2 boxes of Arm and Hammer Baking Soda... cut off the tops and place them in your refrigerator. In 6 weeks change them out.
Now.... there is reason that it can smell and that is that the catch pan under the unit if full of some nasty goo. Unplug the unit Remove the fiberboard rear cover and use a shop vac to clean out the catch pan. While in in the area clean the condenser coils and fan. You can have a deceased rodent under your refrigerator.
Two other things that I use on an empty and dry refrigerator is Mr. Muscle Mold and Mildew Remover (use gloves) first by spraying it on letting it soak for a few minute then wiping it off AFTER scrubbing with an OLD / well worn Scotch-Brite pad. Then wipe off with a damp cloth.... air dry... spray and wipe with Endust (Major trade secrets there) That is how we recondition used appliances.
All of the above should get rid of the odors.
Thanks for choosing FixYa.
Kelly
Oct 01, 2010 | Maytag Refrigerators
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
I have a Honda accord 95 and it smells like something odd. When I bought it, the seller trashed some cigarette packages to make it seem like it smelled like it was a smoker's car (despite knowing he...
My car had odd smells like that also some funky looking stains on the seats, dash and headliner. I used a product called SimpleGreen in just the spray bottle and a damp washcloth and scrubbed the interior down make sure to keep the windows rolled down its pretty strong, it will get rid of the smoke smell but will replace it with the cleaner smell for a week or so, but after that I didn't have any of odors come back.
Feb 24, 2010 | 1995 Honda Accord
Washer makes clothes smell like dog
Hello there:
please follow these simple steps
Instructions Things You'll Need:
  1. Step 1 Balance your washing machine. Standing water breeds mildew and mold. A washing machine that isn't level to the ground stands a higher chance of not draining completely. Take a level and place it on the top of the machine along the front from side to side and then again along the side from front to back. If the machine is very off, you can adjust the feet to compensate or add something under one of the feet if it is not flat against the ground. Portable washing machines are especially prone to have standing water because they are moved around and not leveled each time.
  2. Step 2 Promptly remove your clothes at the end of a wash cycle. If you regularly leave the damp clothes in the washing machine for an extended period at the end of the cycle, you will have mildew in your clothes and your machine. The same is true if you put clean clothes in the dryer and they are not completely dry when the cycle ends and you don't go back for a few days to pull them out. Damp clothes in an enclosed space for days will mildew.
  3. Step 3 Leave your washing machine door open in between uses which gives the machine the opportunity to fully dry out.
  4. Step 4 Use white distilled vinegar in an empty machine. Run a load with only hot water and two cups of vinegar to clean out the machine and freshen the scent. Vinegar naturally eliminates odors and reduces the buildup of soap residue in the washer which contributes to mildew development. You can also add baking soda and/or bleach to the load for both their sanitizing properties as well as assisting in ridding the smell of mildew.
  5. Step 5 Regularly use vinegar when you wash your clothes. Add 1 cup of white distilled vinegar to the last rinse cycle. Vinegar has acidic properties but it is mild enough that it will not harm your fabric. It does dissolve alkalines in laundry detergent which makes for cleaner and softer clothes. The reduction of detergent buildup in your machine will help to also reduce the incidence of mildew.
  6. Step 6 If you have a front load washer, they are particularly prone to mildew and mold. Follow the manufacturers suggestion as to how much and what type of detergent should be used. It is generally less than the traditional top load washing machines. Once again, additional soap residue helps to breed mold and mildew. Also, pull the seals back from around the door and make sure there isn't a build up underneath them that needs to be cleaned out.
  7. Step 7 Finally, if you have done all of the above and nothing seems to work there are commercial products available that are recommended.
Dec 26, 2009 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Damp smell
do a cycle and put a pack of unsweetened kool-aid lemonade flavor only in with it, this also works in diswashers...
Aug 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
82 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
