Question about Microwave Ovens
Hello, we have a Bosch HMT8655GB microwave. This morning, apparently the internal light was on. The door was opened and closed again, but the light remained on. Food was put in and it cooked with no problem. A couple of hours later the microwave's lights were off and it would not function at all. I have changed all the fuses and checked the plugs etc and the problem in inside the appliance. Does anyone know if there is a reset button or combination of moves to reset the microwave or if it is beyond mere mortals!! It is about 2.5 years old and has never had any problems before. Thanks David
  • jkhumpo Apr 07, 2008
    Many thanks for your response, but after trying this and further investigation, it was found to be terinals in the door which had shorted and needed to be replaced.
  • Microwave Ovens Master
  • 981 Answers
Usually Power and Cancel at the same time resets stuff....
Posted on Mar 24, 2008
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
My microwave is cooking without me wanting it to
The fact that pressing CANCEL did nothing leads me to believe the controller may have failed but a failed door interlock could be a contributing factor.
Jan 08, 2014 | Kenmore Microwave Ovens
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Locating the fuse in a hmt8655gb microwave
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jan 11, 2013 | Bosch HMT8655GB Microwave Oven
My microwwave is not heating,
Hello
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
The door on my bosch hmt8655gb wil not shut please can tell me the best way to repair rob
Door catches.
One of the latches may have broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Mar 01, 2011 | Bosch HMT8656GB Microwave Oven
Whirlpool Gold Accubake system microwave indicates door open whenever try to heat. Light (inside microwave) does not come on when door is open. Door open error stays on until cancel button clicked then...
I just had the same problem with my microwave. First DISCONNECT THE POWER. Remove the front top grill (screws are on top of microwave). Unscrew the one screw at the top of the control panel and lift it out of the way. You will see three micro switches to the left of the pannel. I bent the metal frame they were mounted to by hand to move them back into place. The microwave oven works great now. If this does not help, then I would consider replacing the top limit switch.
Jul 13, 2010 | Microwave Ovens
Bosch HMT8655GB, after being used no heat and cuts out at 22 secs
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
e6tuwe
May 12, 2009 | Bosch HMT8655GB Microwave Oven
My microwave is brand new. When I close the door, the dish rotates and the light stays on. Help!
Test 3 Door Switches. Intermittent, Skipping, Maybe Burnt internally or Spade contacts Burnt. Door switches should Open/Close or Closed/Open. A Meter or Continuity Tester Works. Audible Sound Hearing Helps on Continuity Tester. Listen for Nice Clear open-Close or Close-Open sound. If no Sound or Skips ( Intermittent ) Just found Your Problem. One of the Door Switches is Not working right. Now You Can Make & Save Money by Doing it Yourself.
Aug 15, 2008 | GE Microwave Ovens
Microwave
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This may possibly be a door switch issue. The door has to interlock 3 switches to provide safety and performance functions. If the performance function switch fails or is misaligned, it can cause these symptoms. Occasionally you may encounter a "sticky" door switch that may correct itself with a little harder closure of the door. If you are not familiar with how a microwave oven works, I would suggest a professional repairman look at this problem as it involves safety related issues.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 09, 2008 | Bosch HMT8655GB Microwave Oven
Microwave Ovens Logo
176 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
